Magura Marta SL
Status
Not open for further replies.
evil
New Member
Dec 4, 2007
116
2009 Marta Sl from Magura with 160 rotors and adaptors. used for a few months very clean
275.00 for the set
Technical features | Open hydraulic disc brake system with completely
integrated reservoir. New: EBT technology for superfast and convenient
bleeding. Dual piston fixed caliper with automatic pad wear adjustment in a
smart One Piece Design for maximum stiffness. Pad wear thickness can be
checked without removal of the pads. Awesome looking SL rotor for improved
cooling in diameters of 203, 180 or 160 mm (8", 7" or 6"). Featherlight carbon
2-finger blade with integrated reach adjust.
Weight | From 335 g/0.73 lbs onwards (depending on model).
Colours | Silver, red.
Gear Shifter compatibility | Compatible with all Shimano STI, Sram trigger
and Sram and Rohloff twist grip shifters. Not compatible with Shimano
Dual Control. Dual Docking. Trigger shifters can be mounted both inside and
outside the brake lever.
Note | Also compatible with Ventidisc, drilled SL rotor and 90° hose fitting
Guarantee | 5-year leakproof warranty after online registration on
magura.com
Status
16,230
Screeming Yellow Zonker.
