Is not the beam patern in the main pod that provides the wide pattern on the 1400 it is the ears on the mickey mouse what helps
The patterns look different according to "odtexas'" post/pictures; however, I havent actually seen the MagicShine (MS) 1400's beam pattern myself, so I dont know first hand..
(edited out most of the pictures)
1st picture below shows the MS-900 on high;
2nd picture shows the MS-1400, with "Dual XPE only High" which I assume is the little ear LED's because he describes it as "Dual" and also mentions that it is "only" those lights;
3rd picture shows the MS-1400 with the "P7 only High", which I know both the MS-900 and the MS-1400 use SSC P7 LED's, so I would assume that its the main beam of the MS-1400;
4th picture states that both the "P7 and dual XPE" are on "High" on the MS-1400.
Comparing the 1st (MS-900) and 3rd (MS-1400) pictures, which seem to be both "P7" LED's on "high", it seems that MS-1400 has a wider beam pattern.. But theres no telling what camera was used, or if the camera was set on auto-adjust, which may auto-compensate for different levels of light, providing an inaccurate means of comparison.
odtexas said:
MS900 P7 High
MS1400 Dual XPE only High
MS1400 P7 only High
MS1400 P7 and dual XPE High
