bent steel
New Member
I've got a black rear ENO Eccentric Disc hub laced to an 819 Disc, and a black WI M16 laced to a matching 819, both with black DT Champion spokes and black brass nipples. Rear has probably 1k - 1.5k miles and the front has under 200 miles on it. I'd prefer to sell with the eccentric disc mount and the specific freewheel tool for $350 with your choice of WI freewheels between 17t and 20t. Will include pictured black front Salsa stainless skewer and spare spokes (although I've never broken one).
I ran these on my geared 26er for a little over a year, before first building the front wheel to replace a King front, and then buying a devoted 29er single speed. They work very well, the eccentric hub picks up about two to two and half links of chain and allows you to skip the use of a tensioner while still allowing you to change one or two teeth on the freewheel without tinkering with the chain.
Here's the rear in action on the old sled:
