FS: 2008 Specialized Stumpjumper LARGE
Status
Not open for further replies.
pinoiryder
Dec 10, 2007
942
Carson
Hello,
Stock components.. ASKING $1800.00
Bike is in immaculate condition with a little over 100 miles. I used it in about 10 trail rides (nothing extreme) and 2 beach rides (strand) - I'm moving on to a different hobby that's why I'm selling it. The bike was bought in December of 2007. Size is LARGE
To make the deal sweeter, I will throw in items that I bought which I thought I would use... Here's the list:
1pc - 661 Pressure Suit-Short Sleeve (Unused-Brand New)
2-4pcs - Extra tires (Kenda, Panaracer) mounted and riden for about 10 miles each
1pc - CATEYE Wireless bike computer (installed as soon as the bike was purchased, so ODO is accurate)
1pair FOX knee and shin guard
1pair FOX elbow and forearm guard
Will post pics tonight.. here's the specs from Specialized website
FRAME
All new Stumpjumper FSR M5 manipulated alloy frame w/ ORE TT/DT, sealed cartridge bearing pivots, DMD Direct Mount F. Der, replaceable derailleur hanger, disc only, 120mm travel
REAR SHOCK
Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, adjustable rebound, 7.25x1.75"
FORK
Fox Float 120 RL, 120mm travel, rebound/compression adjust, lock out, alloy steerer
HEADSET
1 1/8" threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
STEM
Specialized adjustable rise, 31.8mm clamp, 3D forged w/CNC finish
HANDLEBARS
Specialized XC low rise 31.8mm bar, 6066 butted alloy, 6 degree up, 8 degree backsweep, 640mm wide
TAPE/GRIPS
Specialized thin lock on grip, dual density
FRONT BRAKE
Custom Avid Juicy 5 SL, hydraulic disc, 185 and 203mm rotor
REAR BRAKE
Custom Avid Juicy 5 SL, hydraulic disc, 160 and 185mm rotor
BRAKE LEVERS
FRONT DERAILLEUR
Shimano M581 LX, DMD, top swing, dual pull
REAR DERAILLEUR
SRAM X-9, 9-speed, mid cage
SHIFT LEVERS
SRAM X-7, aluminum 9-speed trigger
CASSETTE FREEWHEEL
Shimano HG-50, 9-speed, 11-34t
CHAIN
SRAM PC-971 w/ Power Link
CRANKSET
Shimano A/A/S 2pc custom
CHAINRINGS
22S/32A/44A, 4 bolt 104/64mm
BOTTOM BRACKET
Shimano M542, 2pc custom for Specialized
PEDALS
Crank Brothers Smarty custom for Specialized
RIMS
DT Swiss custom for Specialized X420, 24mm w/ eyelets, 28/32h
FRONT HUB
Specialized Hi Lo disc, 28h CNC flange and disc mount, sealed cartridge bearing, 9mm DT RWS alloy QR
REAR HUB
Shimano custom M525SL hub for Specialized, 32h, alloy QR
SPOKES
DT Swiss 1.8mm stainless, alloy nipples
FRONT TIRE
S-Works The Captain 26x2.0", 120 TPI, tubeless ready aramid bead, dual compound
REAR TIRE
TUBES
Specialized Ultralite, .6mm, presta
SADDLE
Specialized XC MTB, hollow Cr-Mo rails, SL foam
SEAT POST
2015 butted alloy, two bolt non-setback, 30.9 x 350/400mm
SEAT BINDER
Alloy collar w/ QR, 34.9mm clamp ID
Damn tony
This is the first time I seen you selling not buying:lol:
BTW what are you switching to?
Hey can you post some detail pics? I might have someone who is interested...
same item being sold... with pics included
http://orangecounty.craigslist.org/bik/860538346.html
Link to specs:
http://www.specialized.com/bc/SBCBkModel.jsp?arc=2008&spid=33436
Tony this is the correct specs to that bike. This specific model DOESN'T HAVE "The Brain".
This is the Stumpjumper COMP Model
(Straight from Specialized Site)
FRAME
REAR SHOCK
FORK
HEADSET
STEM
HANDLEBARS
TAPE/GRIPS
FRONT BRAKE
REAR BRAKE
BRAKE LEVERS
FRONT DERAILLEUR
REAR DERAILLEUR
SHIFT LEVERS
CASSETTE FREEWHEEL
CHAIN
CRANKSET
CHAINRINGS
BOTTOM BRACKET
PEDALS
RIMS
FRONT HUB
REAR HUB
SPOKES
FRONT TIRE
REAR TIRE
TUBES
SADDLE
SEAT POST
SEAT BINDER
NOTES
Protective clear coat, derailleur hanger, reflectors, owners manual
Status
