Cleaning the lab have some items up for grabs: 2015 Race Face Aeffect Flat Pedals $65 obo (new take off) OVERVIEW Introducing the Æffect pedal. Thin platform, concave aluminum body with bottom-loading pins. Shorter spindle design shaves weight making it perfect for trail bikes while the chromoly axle and bottom loading hex traction pins ensure it can take abuse and perform double duty on your DH rig. Hidden grease access port allows for on bike maintenance. FEATURES Thin concave platform. Reduced spindle length saves weight. Hex-head threaded pin design offers more bite for added security. Hidden / Grease access port for extended life. SPECS & COLOURS BUILT FOR: Trail/AM/FR/DH BODY MATERIAL: 6061-T6 ALUMINUM AXLE MATERIAL: Chromoly steel HEIGHT: 15-16.9mm PLATFORM SIZE: 101x100mm WEIGHT: 375g BEARINGS: Cartridge bearings and DU bushings # of Pins: 20 SHCS hex traction pins per pedal COLOURS: Black 2015 HT AE03 Flat Pedals (Used ~6 rides) $60 obo Evo series features ultra-thin body for improved ground clearance, reduced Q-factor and a lower center of gravity Extruded, CNC machined aluminium body with dual DU bushings and EVO bearings 10 replaceable pins per side 102 x 96 x 11mm 2015 Deity Bladerunners (New Take Off) $80 obo Deity Bladerunner Pedals Whether you’re approaching a massive jump or rodeoing a jagged rock garden, gutsy riders are always striving to be epic, and like a good friend, your equipment should support that. Deity’s components are intensively designed to beg you to be epic. As its name promotes, the Deity Bladerunner is extruded and machined from 6061 T6 aluminum to a slim 11mm profile. By ridding materials in key areas, the Bladrunner sheds unwanted weight as fast as it sheds mud. Additionally the design widens the footprint to a roomy 103mmx100mm, ensuring riders have no shortage of foot positions. The Deity Bladerunner Pedals feature a concave pin design with 10 allen pins per side and machined traction grooves, for the kind of grip that is essential to riders trying to touch the sky. Upon landing, the load distribution system disperses the impact to prevent bearing blowouts. Consider the Deity Bladerunner your new, very supportive friend. DEITY BLADERUNNER PEDAL FEATURES: Extruded and Machined from Deity molds and 6061 T6 aluminum The largest and thinnest Deity pedal to date Thin 11mm profile at the exterior edges 103mm x 100mm footprint Concave pin profile Load distribution system to prevent bearing blowout Multi micro sealed bearings and Deity DU Bushing internals 10 allen bolt pins per side keep your feet glued Machined traction grooves Minimal material in key areas to shed weight and mud build up Stepped Black polished Cr-Mo axle is compatible with 8mm allen keys or also a standard 15mm pedal wrench Fully serviceable without requiring removal from the bike Rebuild kits available Pedals come with an extra set of pins for back ups Available in High Polished Black, Red, Green, Blue, and Purple Ano with laser logos Also available in White Powder coat Claimed Weight: 370 grams (pair)
