Where To Get Foam Rollers?
Discussion in 'Racing and Training' started by MTBMaven, Feb 19, 2008.
  1. MTBMaven
    MTBMaven This is Shangri La
    GIS Coordinator
    Pasadena, CA
    Where could one find high density foam rollers locally?
  2. aosty
    aosty New Member
    Try Sports Chalet or Tarjay?
    I got mine from the physical therapist. #-o
  3. reflux
    reflux New Member
    A strength training store?
    Pilates store?
    Highly recommended from a source...
    http://www.performbetter.com/detail.aspx?ID=4592&rnd=32&kbid=1186
    Le Targhey stocks a cheapo foam roller. I know because it was my first foam roller a few months ago and it already needs replacing.
  4. kanga
    kanga Active Member
    Eagle Rock
    I went to Sports Chalet and they were way too expensive for the technology, materials and design/engineering work I felt I was getting in return (I don't believe in paying for hype or packaging).
    Instead I went to Home Depot and bought a $2 cut off of PVC pipe, wrapped it in an old towel and sealed with tape. Works for me!
  5. aosty
    aosty New Member
    You mean 20 bucks for a simple length of foam is too much?! ;)
    Nice!
    Nice!
    You now need to come up with a 2-buck substitute for the piece of styrofoam on top of our heads! :lol:
  6. kanga
    kanga Active Member
    Eagle Rock
    No, I mean $30 bucks is too much for a bit of round foam!
  7. Field
    Field Intense Spider 27.5
    I.T. Stuff
    Redlands
  8. sdyeti
    sdyeti New Member
    CA via MA
    I got mine at BusyBody (it's a chain).
    BusyBody site
  9. OffRoadie
    OffRoadie Roadie in Exile
    Electrical Engineer
    San Diego, CA
    I've seen them at Big 5. If you find the pressure from the foam roller to be too much, try "The Stick." I prefer it to the foam roller.
  10. sdyeti
    sdyeti New Member
    CA via MA
    Ooooh...the roller hurts SOOO good, though! ;)
    The Stick is okay but I agree with you that the roller is better.
  11. doublewide
    King
    DTF
    I like your linky to busy body, it takes me to STR! :)
  12. surlygal
    surlygal Bad Girl of DH
    Accountant
    Yorba Linda & Big Bear
    We found ours at Target for 25.00, came with a cheesy video.
  13. sdyeti
    sdyeti New Member
    CA via MA
    Fixed it.
  14. dudevf1
    dudevf1 New Member
    SD, CA
    Go to Sam's, Costco or other grocery store and purchase the largest can of coffee that they have. You may want to reinforce the ends with duct tape so you don't have an accident but this works. It is very painful.
  15. sdyeti
    sdyeti New Member
    CA via MA
    Not long enough to stretch out your back, etc. I guess for one leg only it would work. I roll both quads at once.
  16. dudevf1
    dudevf1 New Member
    SD, CA
    Yes, the Coffee can is limited to IT band applications and that outer edge of quads, the size isn't right for other parts. For the back just use a tennis ball against the wall, better pressure than the roller.
  17. MTBMaven
    GIS Coordinator
    Pasadena, CA
    I notice the product from Perform Better is made from 5" PVC pipe. That seems like a cheap way to go about it. Some foam on the outside would be nice though.
  18. kanga
    kanga Active Member
    Eagle Rock
    That's what the towel is for. I took duct tape and taped one edge to the pipe, rolled the towel around it tightly, then taped the other edge down. Washable too! For more cushioning you could use an extra towel or some packing foam, or neoprene.
  19. MTBMaven
    GIS Coordinator
    Pasadena, CA
    Got it. I totally missed the PVC pipe comment in your original post. I think that's what I'm going to do.
    How long is your pipe? (now that just sounds dirty doesn't it?)
    Much thanks!
  20. TrojanInsomniac
    TrojanInsomniac Active Member
    DPT student
    Madison, WI
