Video card want to buy Video card
Discussion in 'Non-Bike Related' started by mtb_prodigy, Sep 27, 2008.
Thread Status:
Not open for further replies.
  1. mtb_prodigy
    mtb_prodigy New Member
    Anyone have any video cards they wanna sell? I really need one. went on ebay but too expensive.
    I need an AGP video card
  2. DirtymikeTDB
    DirtymikeTDB Guest
    Like what kind of video card????
  3. COLEKO
    COLEKO The Flying Hawaiian
    La Mirada
    May want to point out what type you need, like AGP, PCI, or PCI Express.
  4. mtb_prodigy
    Video Card Minimum: 64 MB DirectX 8.1 compatible video card (NVIDIA GeForce 3 or better) You Have: Intel(R) 82845G/GL Graphics Controller (Intel(R) 82845G/GL Chip)
    [​IMG]FAIL: Sorry, your video card does not meet this minimum requirement. Upgrade to a more powerful video card will make all your applications look better. Click the 'We Recommend' button to see some great options.Video Card Features - Minimum attributes of your Video Card [​IMG]Video RAM: Required - 64 MB , You have - 64 MB[​IMG]Video Card 3D Acceleration: Required - Yes , You have - Yes[​IMG]Pixel Shader Ver.: Required - 1.1 , You have - 0.0
    i need it to play a game
  5. autoduel
    autoduel sandbagger
    Architecture
    Mission Viejo
    I got a ATI Radeon X700 Pro 256mb AGP, but I still don't know what slot you have.
  6. jeffj
    Bloated Mountain Biker
    Castaic, CA
    From looking at his specs, I'd guess PCI or possibly AGP (or maybe on-board?), but he should be able to open the device manager and look at the 'display adapter' properties to determine which type of slot his uses for certain.
    EDIT: Mine says PCI there too, but it's an AGP card. However, if I right click on the desktop and select properties, select 'settings' tab, then select the 'advanced' button, it shows the properties of my video card and there it shows my card as being used by the AGP bus.
  7. mtb_prodigy
    thats what the properties told me
  8. JoeTruth
    JoeTruth Active Member
    Sierra Madre, CA
    I don't know what mobo you have but I do know what chipset you have (845g). Based on that information, I'm about 99.9% you need an AGP video card (AGP 2X/4X, 1.5V Only). NOT PCI-e (express), which is what the current graphics standard is.
    http://support.intel.com/design/motherbd/bv/index.htm
    Be sure you have an AGP slot. Some entry level boards with integrated graphics, didn't always include an AGP slot and some only have a PCI slot. Check inside your computer to be sure first.
    Call around (i.e. Fry's, Circuit City, mom and pop computer shops) and see who and what they have in stock. Someone could have something in stock that they want to get rid of as bad as you want to purchase one. I'd go with at least 128 mb of ram.
  9. jeffj
    Castaic, CA
    Here's a picture showing both an AGP bus and a PCI bus. The top slot (purple) is AGP and the bottom two slots (white) are PCI. Look carefully at the slots and you should be able to determine which one you need. If your mobo has agp, there will only be one and it will be further away from the back of the computer than the PCI slots will as it is in the picture.
  10. CA_descender
    CA_descender IamHAZZMATTseeMEgroove
    Father & Husband
    If you do need an AGP card then go to Frys and buy a new one. AGP is outdated and the cards sell for a lot less then they used to. I picked up a VisionTek Radeon HD2400, 512MB AGP 8x card for about 80$. I believe a 256MB card goes for about 50 or 60 $ and anything less can be bought for about 30 to 40$.
    If you do not like Frys then check out newegg.com you will find video cards ranging from 20$ on up to 500$ depending on your needs.
  11. RC_Compton
    RC_Compton Straight Outta CPT
    EMT for Riverside County
    Riverside, CA
    Wow I didn't know they still had GPUs that were only 64 MB with no pixel shader... How old is your comp? May be time to get a new one... :-k
  12. mtb_prodigy
    It looks like pci
    [​IMG][​IMG]
  13. JoeTruth
    Sierra Madre, CA
    No, that slot to the far top is an AGP slot.
    Dude, you seriously need to blow the inside of that thing out. It is filthy! If you have a compressor, take it outside and blow the shiat out of it. Otherwise, go get some compressed air, take it outside and try your best to blow the shiat out of it. Especially all fans and heat sink beneath cpu fan. That's disgustingly dirty and horrible for ventilation and it will over heat.
  14. mtb_prodigy
    Thanks a lot
  15. dstepper
    www.themostprogram.com owner
    Looks like you have a empty slot for more memory. While it is apart and if you have not maxed out the memory, I would through another stick in there.
    Dean
  16. crashergs
    crashergs New Member
    Carpenter
    INLAND EMPIRE
    damn.... invest that $$$ on a new computer
  17. mtb_prodigy
    If i had money id invest it in a new bike.
  18. DirtymikeTDB
    DirtymikeTDB Guest
    Yeap thats AGP, dirty as well, get some more ram while its apart, clean it, save for a new unit.
    What game are you wanting to play????? Might need a new system if yours is old enough to be running 64 megs, and be on integrated video.
  19. crashergs
    Carpenter
    INLAND EMPIRE
    I got a GTX 280 OCX 1GB ram card for sale
Thread Status:
