Shifting Mystery
Discussion in 'The Workshop' started by pshloss, May 4, 2006.
  1. pshloss
    pshloss New Member
    Los Alamitos
    OK, here's one for the expert mechanic to solve (and no, I don't know the right answer yet): I have a new chain, cassette, and crankset. The chain and cassette are 8-speed (as are the shifters- the rear der is XTR rapid rise) and the cranskset is a 9-speed compatible LX. If I adjust the rear derailleur so it is properly adjusted for the middle chainring, it shifts fine in the middle ring and in the big ring. However, in the small ring, the indexing is off by one full click. It goes into first gear on the second index step, second gear on the third click and so forth. I checked the low limit and the cable tension (in middle chainring) and they all seem OK. Of course the cable is slack on the first click when using the small ring, but if I take the slack out to make it OK on the small ring, then the middle ring is off. The only thing I can think of is possibly the chain is a little too short. I sized it according to the big ring, big cog method with about 1-1/2 links extra. Ideas?:confused:
  2. Neccros
    Neccros Technically Canadian
    Engineer
    Redondo Beach
    I'm totally guessing here, but check and make sure your derailer hanger isnt bent....
  3. jruiz
    jruiz Member
    Azusa
    Bottom bracket spindle length issue?
  4. Neccros
    Engineer
    Redondo Beach
    I doubt its the spindle length since thats consistant and never a variable so either your shifting works or its just whacked through the entire range...
    Also check your cable ends and the ferruls, I had a set of Flak Jackets and the shifting was so slow or not at all due to the ferruls clamping down on the ends of the cables and causing serious drag. The way the shifting acted, you would have no idea it was the cables. Then the Path suggested a cable swap since they dont like flak jackets and sure enough, it was back to shifting like butta after I was done!!!
  5. EndoMaster
    EndoMaster Member
    Professional web surfer
    Los Angeles
    I'm thinking chainline as well. Did you buy one of the newer cranksets with the integrated bottom bracket? You are describing a problem that I had when I installed a Raceface X-type crankset onto a bike that I have. I installed it per the instructions but found that it behaved as you're describing. I adjusted the chainline by moving the drive-side crank inwards towards the bottom bracket by removing one of the spacers that the install instructions called for. Once I did that and readjusted the limit screws on the front derailleur I was able to get the shifting in order.
    Agustin
  6. Neccros
    Engineer
    Redondo Beach
    Might be... I am still running old school cranks and seperate BB so I havent dealt with any of the issues with the new stuff
  7. pshloss
    pshloss New Member
    Los Alamitos
    Thanks for the ideas. I think you guys are on the right track with the chainline. I am going to see what happens after going to the 9-speed cassette and shifters. I did have to change the bottom bracket when I put in the new crankset (it is the older type Hollowtech I octalink, the one i was replacing was the even older square taper type. So maybe the BB is the wrong spindle length. How would I determine the right one? I put in a 68 x 121 because there were only three choices on Pricepoint and the other two were 78 and my old one was 68. Performance Jenson only sell 121 length, too. So I assume that's right. Hopefully, it's just from mixing the 8 and 9 speed stuff. It's rideable, just a little annoying and I should be able to get the 9-speed stuff in this weekend or early next week.
  8. jruiz
    jruiz Member
    Azusa
    Are you talking about the es51 bottom bracket? They say that the LX m752 is only compatible with this bottom bracket. I told that to my budddy when he bought this crankset. He said he bought a es71(specific for the xt) and it fit. I don't believe him, but you might want to check this out. These are available with 113 and 118 spindle lengths.
  9. pshloss
    pshloss New Member
    Los Alamitos
    Yes, the ES51. I might have to check out your suggestion if I'm still having the problem after switching the cassette and shifters.
  10. EndoMaster
    EndoMaster Member
    Los Angeles
  11. dirttorpeedo
    dirttorpeedo drive monkey, drive!
    maint. for a oversized school district
    mtns. of south california
    your spindle maybe too long,there is a meaurement from centerline of the seat tube to the midddle ring. i belive it's 47 1/2 - 50 mm.this is for best shifting. you shood have about a 113-118 length spindle.when you get that part correct put the der. in the small ring and titen the cable.make shur you've got some room to adjust the slack in the cable with the barrel adjuster. MR. shloss, my bill is in the mail. ....hope that helps!
