Mavic UST wheels losing air!!!
Discussion in 'The Workshop' started by noweyout, Jun 22, 2009.
  1. noweyout
    noweyout Can't kick dirt habit!!
    San Gabriel Valley
    My UST wheels are slowly losing air. I remove the tires and check for signs but I don't see any. Last week, I discovered my rear wheel flat. This weekend I discovered both wheels flat. I pump it up and its fine to ride. I am going to check the rubber O-ring for the valve stem and see if it's leaking from there. Anybody else have experience with this?
  2. un-kola
    un-kola Just another Homer!
    Retired!
    Murrieta, Ca.
    Add a couple of scoops of Stan's sealant.I usually lose a little air when I first mount a new ust or 2-bliss tire on my rims.After a few weeks no problem.I usually check the pressure once a week and air up accordingly.-Lloyd :wave:
  3. tradersancho
    tradersancho New Member
    Software Engineer
    Mission Viejo
    When I ran Maxxis High Rollers (UST but not LUST) on a UST rim they used to lose 10 psi a night. Then I switched one of them out with a Crossmark (LUST) and it held air well for a while, then it started losing like 10 psi a night. I dumped a couple scoops of stan's sealent in each tire and neither of them leak anymore :)
  4. Piranha
    Piranha Member
    Pasadena, CA
    Are you sure the entire bead is seated properly? I have only experienced this issue when the bead was not seated right. I have yet to see a UST wheel leak from the valve stem and the only way I believe that could happen is if it were damaged/defective.
    BTW, they still make tubes? What a waste IMO.
  5. DirtymikeTDB
    DirtymikeTDB Guest
    Oh Oh Oh..... I have a great idea to figure exactly where you leak is.........Fill your tub with water, and dunk the inflated wheel under, look for bubbles. Then youll know for sure where the leak is
  6. noweyout
    San Gabriel Valley
    Yeah, I think i'll do that this week. The wheels were mounted for about 5 months w/o having to +/- air pressure. Just happened suddenly.
  7. pitmang1
    pitmang1 Member
    put a tube in it ;)
  8. Pain Freak
    Pain Freak Dead or Alive
    Da Boss
    Fontucky
    What tires are you running?
  9. 1080P
    1080P Banned
    The 818 curtain
    Are you running UST tires with your UST rims, or are you cheaping out and using regular tires? Only thing left is valve core not sealing and gummed up or not sealing at the rubber grommet where it joins at the rim with the valve lock ring.
  10. noweyout
    San Gabriel Valley
    I have nevegal UST on my UST rims. I dont' really want to use Stans in them. Do you guys perform any special type of maintenance on your UST wheels?
  11. dstepper
    dstepper Over the hill
    www.themostprogram.com owner
    Why no Stans? If they are not new tires and you have been running them they may have some holes in them from thorns or small slidewall tears.
    Take some soapy water and a brush and see where you are losing air.
    Dean
  12. un-kola
    Retired!
    Murrieta, Ca.
    That's a waste!:lol: -Lloyd :wave:
  13. Tedroy
    Tedroy Active Member
    Designer Web/Graphic
    Pasadena Ca
    +1 on the Stan's juice...
    ... I know it adds weight, but suck it up. The whole point of UST is to be as bullet-proof as possible. No one likes to stop for flats on a trail ride. Racer boys may want to run em dry, but most folks use tubeless rigs with juice of some kind inside to keep the flow going. Try it, you'll like it!
  14. noweyout
    San Gabriel Valley
    So I removed the tire and inspected it. Nothing. I made sure the valve stem and o-ring was clean/not cracking. Clean. I did the water test and BAM!!! Air was leaking out of all the nipples. I am depressed now.
    I am thinking the quick fix would be stans. Any suggestions?
  15. Pato
    Pato Stop stealing my thunder!
    Computer/Networking nerd
    Downey, CA
    Replace the valve and/or use Stans. If it's only on one wheel, you can try taking the valve from the other good wheel to test if it's the valve. If replacing the valve fixes the problem, just get a new one. If it doesn't, I'd inspect the inside of the rim wall carefully for cracks.
  16. moment8
    moment8 Member
    King's Body Shop & Autocare
    near Fully Loop
    Stans Is Good +2
  17. DISCO
    DISCO Banned
    Stans is still dangerous garbage, don't risk it.
    UST rims are not drilled, so since the bead is not leaking the only way you could pressurize the spoke bed is through the valve stem hole. Make sure the O-ring is seated snugly but not too tight, try a little grease or Vaseline and it should seal up fine. If that fails O-rings are less than a dollar everywhere just make sure it's not super tight (they seal on compression but if pushed too much they will deform and leak).
  18. noweyout
    San Gabriel Valley
    Good point. I'll try a little grease! Thanks!
  19. skflow
    skflow Member
    Engineer
    OC
    double post
  20. DirtymikeTDB
    DirtymikeTDB Guest
    Kinda already covered that.:beer:
    Before going too far, what wheels are these?
