Help! I can't get my darned tire off the wheel!
Discussion in 'The Workshop' started by ofcounsel, Nov 17, 2012.
  1. ofcounsel
    ofcounsel Member
    Ok. So I've been riding for 20+ years and have taken tires on and off wheels hundreds of times. But now I'm stumped.
    I've got a set of Easton Haven's and a WTB Wolverine Tubeless tire. It was tough, but I got one side of the bead to release. Now I'm trying to get the the side bead to release from rim, and it won't release. I can't fit a tire iron in between, and I've tried shoving a flat head screwdriver in there. I just tore the tire is all.
    Any ideas? Help!
  2. da big hills
    daily night grind
    Conejo Valley
    make sure the tube is deflated, use windex for a lube
  3. HardtailBlazer
    HardtailBlazer Member
    Mission Viejo, California
    is it suctioned on?
  4. ofcounsel
    ofcounsel Member
    It might be suctioned on. It was set up tubeless. I got one side of the tire to break loose and off the rim. The other side won't release though. It's strange.
  5. emcil
    emcil my wife no like me
    Spring Maker
    San Dimas
    Torch?
  6. ofcounsel
    ofcounsel Member
    Are you serious? A torch? I don't think that's the answer...
    Here's a pic. The bead won't break loose on one side.
  7. bing!
    have you tried using two tire levers to push down on the bead to break the set?
  8. ofcounsel
    ofcounsel Member
  9. gooseaholic
    gooseaholic Active Member
    Auto inspection
    Orange,ca Via Seattle, WA
    fill the inside of the rim with brake clean and light it on fire. Should break it loose without damage to the rim. Its kinda like seating a bead on the trail when 4x4 driving.
  10. dubk
    dubk New Member
    prop it on it's side so one end is on the floor and the other a about a foot of the ground, push down on the tire at the bead, hands at 1 and 11, tire will just pop. mine does exatly the same.
  11. emcil
    Spring Maker
    San Dimas
    Sorry, I thought my comment of "torch" was so far out there it would be obvious I was joking. After reading it again I can see where some might think I was serious. Good luck
  12. jasonmason
    jasonmason inebriate savant
    Geologist when I have to work, which is too often.
    Sacramento
    And here I was about to recommend c4...
    Sigh. Oh we'll, maybe next thread.
  13. strobe
    strobe resident noob
    I have strangely heard of ppl using glues to get the beads to seal up. I bet you, once you get a portion to release, the rest will be easy.
  14. ofcounsel
    ofcounsel Member
    This worked. Thanks!
  15. dubk
    dubk New Member
    Glad to hear!
  16. mtnbikej
    mtnbikej Well-Known Member
    The new WeirWolf is notorious for being a very tight fitting tire......especially on non-WTB rims.
    Ooops.....yours is a Wolverine. #-o Nevermind.
  17. 7pt
    7pt New Member
    I have heard prying with screwdrivers against the bead/rim is good for tubeless setups...
  18. un-kola
    un-kola Just another Homer!
    Retired!
    Murrieta, Ca.
    Hey Timmaaaay! How's life up in Sacto? Using C-4 isn't far off. We used to use it to heat up our c-rations in the bush, overseas. Ball up a small chunk, drop into your c-ration stove,( an empty can, slightly crushed at the top with holes punched on the bottom), light off with a match. Took about 30 seconds or so to heat up. Then you can kick back and enjoy your favorite can of ham and mutha fu.... uhh, ham and lima beans (yeccchhh #-o)! -Lloyd :wave:
    7pt, using a screwdriver on an aluminum rim is not advisable. -Lloyd :wave:
  19. 7pt
    7pt New Member
    That's kind of the point i was making
    first post "I can't fit a tire iron in between, and I've tried shoving a flat head screwdriver in there. I just tore the tire is all."
  20. bleicht
    bleicht Member
    Heck yea, this worked for me too... Thanks!! I propped it up on a one of those foam rollers just on the very edge of the rim so as not to damage anything. I tried like hell before using this method and it wouldn't budge.
