chain size
Discussion in 'The Workshop' started by gurp13, Aug 16, 2006.
  1. gurp13
    gurp13 SolarFederationMember
    High School Teacher
    Fontana, CA
    My commuter bike is 21 speed. Three chainrings and seven sprockets. So, I assume that means I need a 7 speed chain. But, all I see are 8, 9, and 10 speed chains. What do I do? Will the 8 speed chain work?
  2. P-Funk
    P-Funk Member
    Graphic Designer
    Orange Curtain
    An 8-speed chain should be fine, I'd think. The only difference would be the width of the chain; an 8-speed chain being narrower than a 7-speed.
  3. Pho'dUp
    Pho'dUp Spam Musubi MasherSS
    P-line rider
    8-speed chain should be fine. 7 and 8 are interchangeable. Cheap too.
  4. Jordansrealm
    Jordansrealm New Member
    Photographer/Editor
    Rancho Santa Margarita, CA
    8 should be grand
  5. Innes
    Innes Member
    Teacher
    Alta Loma, CA used to be Pgh.
    I believe 7 and 8 speed chains are the exact same. They didn't need to change the width of the chain until they went to the 9 cog cassette.
  6. gurp13
    High School Teacher
    Fontana, CA
    That sounds pretty unanimous. Thanks, you socaltrailriders, you!
  7. dirttorpeedo
    dirttorpeedo drive monkey, drive!
    maint. for a oversized school district
    mtns. of south california
    yes little one,7/8 is the same shane, if you look some say 7/8 speed on the box.but then you shood have known!happy shopping come back soon.
