Bike Cleaners/Lubricants.... (merged threads)
Discussion in 'The Workshop' started by Dino Brown, Sep 24, 2008.
  1. bing!
    Odorless mineral spirits and this....[​IMG]
  2. UPSed
    UPSed SPECIALizED
    Simi Valley
    Chain cleaner?
  3. Sprankle
    Sprankle Chicks Dig Scars....
    Software Development
    Newport
    +1 Simple Green
  4. mtnbikej
    mtnbikej Well-Known Member
    Simple Green in a Gatorade bottle.
    Soak, shake, soak, shake, compressed air, wipe clean/dry with rag.
  5. destroyer
    destroyer I build jumps
    Hesperia
  6. F.A.D.
    F.A.D. POWERED BY MUSUBIS
    Feeds me
    Alta Loma
    cassettes, chains, crank arms, chainrings, derailleurs, most small parts. It actually works well even though I'm usually not a proponent of cheap tools. I usually use a 50/50 mix of water and simple green and use the heater. I've even been able to dunk small engine parts (small carbs, valves, lifters, etc..) as well.
  7. wheeler
    wheeler Member
    Rock n Roll Gold chain cleaner and lube all in one.....great product
  8. Preludedriven
    Preludedriven Member
    Graphic Designer
    Rancho Cucamonga, Ca
  9. bvader
    bvader Long Live The Gorn!
    Tech Guy
    Huntington Beach
    Sooo most of you are using the take the chain off method, so if you are running a shimano 10sp XT chain for example (non-SRAM Powerlink) what are you using for a quick link....
  10. riiz
    riiz Member
    Redlands
    Simple Green in the park chain cleaner tool. I run the chain through twice letting the last application sit while I hand wash the rest of the bike.
  11. Pho'dUp
    Pho'dUp Spam Musubi MasherSS
    P-line rider
    Simple green too.
    Or just soapy water and a chain cleaner or brushes and rags.
    Hell, it's dusty Socal. If you use a dry lube, or something light like RocknRoll Gold you can probably get away with just blowing most the light dirt off with a compressor and a rag and just re-lubing.
  12. Waldo
    Waldo Lebowski Urban Achiever
    Foothill Ranch... but my credit card lives at The
    What?....you're supposed to clean your chain? #-o
  13. bvader
    Tech Guy
    Huntington Beach
    Yeah actually the more careful I am ... example using Dumond (plastic based) etc... apply sparingly...and regularly wiping down the chain... I rarely actually need to clean the chain...
  14. strobe
    strobe resident noob
    Thats what i do. I don't see a reason to do more. Sonic cleaning or soaking in spirits seems like overkill. But, i buy inexpensive chains and only look to get a season out of it.
  15. irv_usc
    irv_usc Active Member
    Anaheim Hills, CA
    I use a wippermann connex with my shimano chain.
  16. noweyout
    noweyout Can't kick dirt habit!!
    San Gabriel Valley
    Wow, people sure go to great lengths for a clean chain. I use Finish Line Speed cleaner and a rag.
  17. gooseaholic
    gooseaholic Active Member
    Auto inspection
    Orange,ca Via Seattle, WA
    brake cleaner.
  18. Makoto
    Makoto Outdoor'ist
    Los Angeles, CA
    I'm curious about this too.
  19. gooseaholic
    Auto inspection
    easier to clean. Just let it soak. Much faster and gets the chain cleaner than using a brush.
  20. gooseaholic
    Auto inspection
    oh, if I recall, you can use the powerlink on shimano chains. Pretty sure Ive done it before. I could be wrong tbough. I solely use Sram nowadays.
