Where to buy protective tape for a frame/fork.
Discussion in 'General Discussion' started by gooseaholic, Mar 30, 2009.
  1. gooseaholic
    gooseaholic Active Member
    Auto inspection
    Orange,ca Via Seattle, WA
    Just thought I would ask rather than driving around and taking a hit and miss. I had some custom stickers made for my fork and want to cover and protect them before I go riding today.Thanks in advanced.
  2. F.A.D.
    F.A.D. POWERED BY MUSUBIS
    Feeds me
    Alta Loma
  3. 2wheel_lee
    2wheel_lee Active Member
    North Orange County
    I bought a 25' x 6" roll from Autozone a couple years back for about $25. I've used it on a lot of bikes and cars, but it's about finished. The stuff works great! I also do the outside of the seat and chainstays for Snow Summit, where the hacks just throw the bike on the lift and the side of the bike swings against the chair frame.
  4. singlespeedrider
    singlespeedrider Member
    Vestal Watch
    I got some clear plastic tape at ACE hardware. I used it to protect from cable rub, I am sure with would work for stickers.
  5. 2wheel_lee
    North Orange County
  6. BrewMaster
    BrewMaster Thirsty
    Chemist
    Foster City, CA
    I've heard people say there is a protective film you can buy at Home Depot, but I don't know what it's called or where it would be found in that massively disorganized store.
    Leave it to Ken to find the most expensive tape possible.
  7. gooseaholic
    Auto inspection
    Sheese Ken I don't want to spend 100 for tape.:lol:
    Hey thanks Lee. Im gonna check out Auto Zone. I had some cool blue and Orange boxxer stickers made for the goose. B-40 made them. He does good work. So props to him.Here is what he did. Looks great on the bike.
  8. dubjay
    dubjay Having upgraditis is OK
    Work for publisher of fashion magazines
  9. F.A.D.
    Feeds me
    Alta Loma
    Fine!!! Just wrap the crap out of it in SCOTCH tape then.....:lol: Ya cheap bastige!;)
    The 3m stuff does work awesome on the front edges of the race cars! Does a heck of a job protecting the expensive paint. I usually just cut the rems into the shapes I need to use on bikes.:wave:
  10. gooseaholic
    Auto inspection
    Hey, whats wrong with scotch tape? No for real Ken, did you have to buy all the prep stuff first, or can you just apply it to a clean frame?
  11. F.A.D.
    Feeds me
    Alta Loma
    I usually use make sure that the surface being covered is cleaned with no wax residue and then use a mid-temp reducer to make the tape flow over the undulations of the frame/bodywork. You'll end up with a bubble free surface that you would have to look pretty hard to see that it's even covered. On bike frames, I usually only cover the surface that the cable is rubbing on and cut the tape to size just a smidge bigger than the rub mark.
  12. 2wheel_lee
    North Orange County
    I always clean the surface with rubbing alcohol, then use a heat gun to heat up the surface and the clear tape. After applying the tape, I again go over it with the heat gun.
  13. Marshall Willanholly
    Marshall Willanholly Active Member
    Portland, OR
  14. Ladd Jasper
    Ladd Jasper Full speed, half blind
    Russia, with love
    I use clear shelf liner from Ace Hardware. It isn't nearly as tough as the 3M stuff or helicopter tape, but it's cheap as hell and gets the job done.
    It has an opaque finish, so may not be the best solution if you want to see what's underneath clearly. It works great on matte and raw finishes, though, and is a perfect guard against cable rub.
    As for application, make a template out of paper first, then simply trace the shape onto your film of choice. You can fine tune the shape before peeling the backing off and applying. Works great.
  15. volcomsteban
    volcomsteban New Member
    Shmo
    Right neear da beech
    Say it with me...........
    DUCT TAPE
    :lol::lol::lol::lol:
