When do you change a full face?
Discussion in 'The Adrenaline Factory' started by bing!, Mar 26, 2013.
  1. bing!
    HELMET!
    Ive got two crashes on mine and just bought a new one.
    The first crash wasnt really a head hit. It did scratch the out side shell, just a glancing blow. My shoulder took most of the hit.
    The second crash was saturday. I went OTB, and took a hit to the right temple. Besides scratching up the visor, there was no other sign that the helmet took a hit.
    What convinced me to buy a new helmet is that I have a bruise on my cheek bone. Not much, just light blackening, but still a hit taken from inside the helmet.
    Would you retire this helmet like I did?
  2. Runs with Scissors
    Runs with Scissors Climbing > desending
    2015 Giant XTC
    Anaheim
    I would have probably retired it on the first hit. Definitely on the second. Used to ride motorsickles and always knew that even dropping the helmet was enough to retire it. You did the right thing.
  3. herzalot
    herzalot Well-Known Member
    EdgeUCater
    That advice does not match the image portrayed by your screen name!
  4. me and my bike
    me and my bike New Member
    man of many trades
    The OC
    :lol:
  5. me and my bike
    man of many trades
    The OC
    as far as the helmet goes I would have retired it. A really good piece of advice I was given when I was skeptical if I hit my head crashing, was that if it was a good helmet, you wouldnt know you hit your head. Better safe now than sorry later.
  6. doublewide
    King
    DTF
    I'm a Troy Lee guy myself, but if you continue to crash on your head this might be the way to go. It can withstand multiple impacts (so they say).
    A couple of my friends have this model and love it.
    http://www.pocsports.com/en/product/1220/cortex-flow
    A
    nd you did the right thing by retiring it.
  7. mfoga
    mfoga Intense Whore
    Unless its has a foam designed for multiple impacts I would replace after any heavy impact. Even dropping your helmet can damage it. I have never heard Troy Lee had the right type of foam for multiple impacts, however many say since its DOT helmet it can take extra impacts but there is no evidence of this.
    POC uses EPP/SEPP and ProTec uses SXP. Every other company I know of uses EPU or something like that every hit leaves a dent in the foam, which mean less protection in that spot.
  8. UPSed
    UPSed SPECIALizED
    Simi Valley
    The inside of the helmet absorbs the impact so even though the outside shows no damage the helmet is still compromised.
  9. doublewide
    King
    DTF
    I never said Troy Lee helmets can take multiple hard hits. And not all TL helmets are D.O.T. approved. I did have a TL Air (moto) helmet that I crashed hard on and the inside shell became loose so it was retired.
    You probably know more than me since you crash a lot! LOL Kidding Mark, just kidding.....
  10. bing!
    i got a bell drop. when i have some extra cash, ill go buy a poc flow with epp foam. its. supposed to take multiple hits.
  11. ManInAShed
    ManInAShed New Member
    Destroyer of worlds.
    Yellowknife / Windansea
    When it smells like putting your head in a dirty sock.
    ...also whenever you crash on it.
  12. bing!
    Oh, man! You have got to try some laundry soap and a shopvac. You wouldn't throw out a good shirt if it smells would you?
  13. ManInAShed
    Heh... I's jus kiddin bout that.
    Some third-party lab eons ago did a thorough test of helmets on the market, and found the foam liners disperse and absorb the first impact, but split and crush to do it, and worse, stay crushed near the unseen outside surface of the foam... when the hard shell springs back from deforming, it leaves an air gap where the foam used to be. So the second impact, there's nothing but air between the hardshell that super-dense foam, which then transfers a ton of force to your skull, and it's that force that makes your skull wallop your brain internally that is the #1 thing the helmet is trying to prevent. After that all the helmet MFGs put in their fine print that helmets should be replaced after any impact.
    I'm pretty lax about my helmets.
  14. bing!
    Yeah, thought as much. EPU and EPS foam helmets are one hit wonders. EPP is a multi hit material that forms back. POC makes em. I'm grabbing one soon as I find them at a decent price.
  15. Runs with Scissors
    2015 Giant XTC
    Anaheim
  16. northshore
    northshore Active Member
    It's a gig...
    Laguna Hills, CA
    I AutoX and Road Race a ton. I would A) Ditch the helmet upon first impact or B)When the rating has expired. IE: SNELL or M ratings.
