thru axle stuck in hub
Discussion in 'The Workshop' started by hobie, Nov 28, 2009.
  1. hobie
    hobie Member
    i have a 20mm thru axle that wont come out of a hope pro 2. it rolls just fine but i have tried tapping it out and it just doesnt budge. :?:
    and yes, i loosened it from the fork:lol:
  2. live_in_hilo@yahoo.com
    [email protected] hilo boi
    hvac
    whittier via:hilo, hi.
    wow, i think "drop d" had the exact same issue. maybe hell chime in on what he did. good luck.
  3. Hoosierdaddy
    Hoosierdaddy I Drink Therefore I Am.
    School Bus Mechanic.
    Lake Florest
  4. hobie
    hobie Member
    so sawzall it is my only choice?:?:
  5. gray
    gray Tree Hugger
    Graphic Designer
    Upper Newport Bay
    What fork is it? RS?
  6. Drop D
    Drop D New Member
    Un-Employed
    LBC
    Lol NO! I was just impatient! after I tore mine up, first thing I noticed was that the bearing housing was rusted and was stuck to the maxle... I had to hammer the bearing off...
    just be patient and keep soaking it with WD40 or something similar... GOOD LUCK! and stay away from any SAW :lol:
  7. gray
    gray Tree Hugger
    Graphic Designer
    Upper Newport Bay
    Ftw:
  8. Chewyeti
    Chewyeti Circus Bear
    Yorba Linda
    Aerokroil is the best 'come un-stuck' penetrating lube ive ever tried.
    Try some heat.
    Heat Beat Repeat.
  9. Seth Kendall
    Seth Kendall New Member
    High School Science Teacher
    Loma Linda, CA
    *snicker snicker* New tag line!:clap:
  10. RustyIron
    RustyIron Rob S.
    La Habra
    Back it up. In other words, lay the fork on it's side, and place 4x4's beneath it so the axle is perfectly vertical and flat. When you whack the axle with a leather/rubber mallet, all the energy is imparted onto the bolt and not used up with the fork. The better you back it up, the more energy is applied to the job of loosening the axle.
  11. Hoosierdaddy
    Lake Florest
    Try pouring Coca-Cola on it. Seriously! It can dissolve rust and oxidation. If you've every soaked an oxidized penny in Coke you'll see. We use to soak Jet Ski engines that were rusted up solid and it would usually free them up so we could disassemble them for repair.
    My Cousin who is a plumber says they replace the drain pipes at McDonalds every two years because the Coke erodes the pipes.
    That's why I don't drink Coke! :beer:
  12. hobie
    hobie Member
    thanks guys for the replies. i will let you know how it turns out!
  13. ntsqd
    ntsqd New Member
    paid to play with engines & fire!
    I think Coke works because of the Carbonic Acid in it. A stronger acid that still isn't nasty (ala Muriatic, which I would never suggest) is in vinegar, and vinegar doesn't have all of the sugary yuk in it. Smells a little funky, but that goes away with a little time.
    I'd try "PB Blaster" for soaking it. If you can get it warm first w/o harming things I'd do that too.
    X eleventeen on backing it up.
    HTH & GL!!
