FyrFytrRyn
RTB to a WNL
well it seems to be one thing after another with this ****ing bike. 3rd run @ southridge this morning @ the rock drop, my rebound went out the window, fork shot to full droop faster than you can say "holy s***", hard too, pogo stick status. stopped and ran the reb. adjuster full + with no change. *sighs and takes anger out on a rock innocently laying neer* so i load up and went home (i did see rob {bikebike69} for a moment though). i took the fork apart to find the rebound side cart to be in pieces, snap ring gone, o rings gone, general destruction on the right side of the fork. the compression side looks okay and felt the same it did a few weeks ago when i changed fluid, as in, when its full+ its stiff, full- its light, but should i replace both carts?( i think they are 150.00 a piece though!!) i know ill rebuild all new seals and such while im at it, should i get orig. marz seals or get those sweet blue enduro ones? which do you suggest?
better than stock?
http://enduroforkseals.com/id53.html
so my questions for you are:
1. stock seals or enduro ones?
2. if you were me, would you do compression eventhough it feels good?
3. any other tips that would be considered when doing this, anything else i should do while i have the bastard apart?
im up the creek until monday i guess when i can get in touch with marzocchi. this is total BS
rotest:
better than stock?
