specialized*Rider
SloRida
FS: Specialized Enduro $1100
I've had the bike since jan 06. but havent used it much. everything is all original no scrathes. the bike is like new. I bought it for $1899. + tax Frame size is Medium.
these are the specs from the specialized website.
FRAMEA1 Premium Aluminum TransForm Monocoque FSR frame, ORE technology DT, sealed cartridge bearings, two geometry setting flip flop link, replaceable derailleur hanger. 5.2? travel.
REAR SHOCKFox Float R, with ProPedal damping, air spring and rebound adjust, 7.625? x 2.0?
FORKMarzocchi EXR Race. 120mm travel, air/coil spring, rebound adjust. Alloy steerer.
HEADSET1 1/8? Threadless, 3x sealed, black alloy cups, cartridge bearings, ultralight alloy top cap and bolt
STEM3D forged CNC machined, 4-bolt, 6 degree rise, black
HANDLEBARSSpecialized Enduro Mid Rise 31.8 OS bar, 6066 alloy, 6 degree upsweep, 8 degree backsweep, 640mm width
TAPE / GRIPSSpecialized MTB grip, black, double density Kraton
FRONT BRAKEAvid BB-7 Mechanical disc 8? clean sweep rotor
REAR BRAKEAvid BB-7 Mechanical disc 6? clean sweep rotor
BRAKE LEVERSAvid FR-5
FRONT DERAILLEURShimano M-570 LX, 34.9 clamp, bottom pull
REAR DERAILLEURShimano M-750 XT, long cage, standard spring
SHIFT LEVERSShimano M-510 Deore, 9-speed
CASSETTEShimano HG-50, 11/34
CHAINShimano HG-73
CRANKSETCustom Shimano Hollowtech, Octalink XT Spline
CHAINRINGS44Ax32Sx22S, 4-bolt 104/64mm pattern, steel chainring bolts
BOTTOM BRACKETShimano ES-30 Octalink spline, 68mm shell, 118mm spindle. 50mm chainline.
PEDALSN/A
RIMSCustom SUN SOS 28mm wide Enduro disc rims, 26?, black, eyelets
FRONT HUBSpecialized Stout disc, 32 hole, sealed cartridge bearings
REAR HUBShimano M-525 Disc, 32 hole, loose ball bearings, alloy Q/R
SPOKES2.0mm black stainless, brass nipples
FRONT TIRENew Specialized Enduro 2.3?, aramid bead, 60 TPI, dual compound
REAR TIRENew Specialized Enduro 2.3?, aramid bead, 60 TPI, dual compound
TUBESSpecialized presta valve
SADDLESpecialized Enduro, hollow Cr-Mo rails
SEAT POST6061 Butted Alloy, black, 30.9 x 350/400mm. Non-offset.SEAT BINDERAlloy collar with Q/R, 34.9mm clamp I.D., black
CHAINShimano HG-73
PEDALSN/A
