singleSSpeedster
Rolling on 29" dubs!
- Joined
- Sep 22, 2005
- Messages
- 375
- Reaction score
- 0
cycleops fluid 2 trainer with riser block, very good condition. probably on of the tp 5 fluid trainers you can buy. about 1 year old, but seldom used...maybe 10-15 hours on it. selling for $150 (retails for $235 with riser block lnline).
hope mono mini hydro disc brakes. 2005 brakeset. 180mm/160mm rotors. classic gold ano. great conditon, recently re-bled rear system. front system has EXTEREMLY low miles. LOTS of pad life left. selling set for $230 (retail online is $200 front and $150 rear at most places, $350 total).
seven cycles titanium flat bar. 26" wide, 8* bend. standard 25.4mm clamp with shim (this is NOT an oversize bar). awesome, lightweight, duable cushy bar. forget about carbon. $85 ($150 at seven cycles).
seven cycles titanium 26" flat bar with 11* bend. 25.4mm clamp with shim. $85($150 at seven cycles).
salsa pro moto aluminum flat bar. 26" wide, 11* bend. black ano. $20 ($35 at aebike.com).
29er disc-ONLY front wheel. Black Hope Pro2 hub, black Velocity VXC rim. Laced 32H, 3 cross with DT Comp spokes and brass nipples. all black wheel with silver nipples. 2 rides and 100 miles on them. perfectly true. professionally built by hand. $140.
29er rear wheel. Both disc AND V-brake compatible. Hope Pro2 rear hub. DT Swiss TK7.1 rim. 32H, 3 cross laced with DT Comp spokes and brass nipples. All black wheel with silver nipples and silver machine sidewalls on rim. 2 rides and 100 miles on them. Professionally built, totally true. $250.
sdg i-beam seatpost and saddle. aluminum seatpost is 27.2mm x 350mm long, 265mm is the max length you can have it extended (85mm minium insertion). black post. black i fly c saddle a cabon style i-beam composite rail and kevlar corners. very adjustable, very light, very strong. good condtion with some scratches on the post. $45 for the saddle and post (they retail for $45 each).
syntace superforce stem. 105mm x 6* rise. black. standard 25.4mm clamp. super strong/stiff. also, very light. as new. $35 ($80 at speedgoat.com).
everything is in used but good condition (*some parts are in excellent condition). email me at [email protected] with any questions.
everything has xc miles on it. i don't have any skillz....so there aren't any big hucks on anything!!!
i will try to get pics up soon. but, if you REALLY want something....email me.
i typcially ride in turnbull canyon and the SM mtns. Though, I might ride at Marshall Cyn this Sat.
TIA
TIA
