How to fix "Understeering"
Evil Chocula
ah buh bye now
Jul 24, 2007
1,992
Boston
OK, so I've determined with a fair amount of certianity that my '05 Reign is "understeering", ie the front wheel slides out on turns (vs oversteering; sliding rear wheel and neutral steering; the way it should be). I have a 140mm fork and around a 90mm stem...
So, how do I fix that? Longer/shorter stem, handlebars, fork, etc?
Thanks in advance!
First
swear your allegiance to the Angels and I will tell you what you need to know.
oh never mind.#-o Without seeing a picture of you on your bike it is hard to tell.
However.....
Before changing anything on your bike
maybe work on your technique.:?: You may already know this but here you go. When going into a turn get your weight down vs. back. By lowering your center of gravity and putting more weight on your front wheel you will get better traction.
Give it a try!
Beat me
In my opinion, the stem length and fork travel is fine (the same setup I use on my XC bike).
There are a few reasons your front tire could be "washing out."
1. Too much air pressure in the front tire. Try lowering the pressure.
2. Wrong front tire for the terrain.
3. Although this is the number 1 cause, I'll list it last (because it's easier to blame equipment) - you need to get more weight on the front tire. In addition to moving your weight forward, weight the outside pedal more.
4. Go to step 3 and repeat.
to it:lol::beer::bang:
It could be a lot of things such as tire pressure, fork settings, or body position.
I find I run into the same problem if my fork has too high a spring rate or if my front tire pressure is too high. Most often it can be traced to me not keeping my body weighted evenly between the wheels while cornering. I still have the nasty habit of hanging off the back too much. Too much weight on the back = no traction up front.
edit: damn, you all type way faster than me...
1. 30 Psi... lower than that? I'm 170 pnds.
2. WTB Velociraptor... pretty legit for SD.
3. Could be... but my XC hard tail does not exhibit the same qualitys, which points me to....
Front end set up/geometry?
I3. Although this is the number 1 cause, I'll list it last (because it's easier to blame equipment) - you need to get more weight on the front tire. In addition to moving your weight forward, weight the outside pedal more.
well said lee, i was gonna say something along those lines.
You need to adjust your riding style for the slack head angle of the bike. Lean the bike in the turns not your body. TKBlazer posted a video on this a while back, I'll try to find it. Basically lean the bike as much as you can by extending your inside arm and try keeping your body at a 90 degree angle to the trail. You won't need nearly as much input through the bars when turning this way and your weight will be centered over the wheels for more traction. A shorter stem will probably help, and adjust your fore/aft position untill you find the sweet spot. Good luck.
The head angle of this bike is likely slacker than your XC bike. Given the same body position, this will cause the front end to slide out more than your XC bike. In an over-exaggerated example, you'll notice guys ride way over the bars on DH bikes, to compensate for the slack head angle, and to essentially steepen the head angle by compressing the fork.
So since you're comparing this bike with your XC bike, you'll need to change your riding style for this bike. Because I ride many different type of bikes, I also have to learn to adapt my riding style to the bike I'm riding. And until I do adapt, I also have steering problems.
Now, this makes sense to me. Thanks!
So, I assume a slacker head angle makes steering a little more difficult on flatter terrain (while seated) as well?
And, I'm considering switching tires front and back to Small Block 8s. Comments?
6" AM bike and an xc hardtail is going to have drastic geometry differences. The 6" bike is slacker and putting more weight towards the rear, hence your need to center yourself more on the bike
i had the same problem (still kinda do), and nam had kinda pointed it out to me and i focus hard on staying slightly more forward than what i am accustomed to and it works wonders on the fast sweeping turns.
I have the same bike as you and I had the same issue for a while, but it's getting better.
I think Lee has it nailed. I have a fork that goes from 130 to 150mm and I originally had it at 150mm and for the same reason brought it down to 140mm and it improved the steering, but learning to put the weight (or pressure) on the front in turns has improved my cornering far more drastically and it continues to improve the more I work on it. So much so that I am going to let the fork back out to 150mm and I think I'll be fine.
I also tried a short stem (tried several all the way down to 90mm), but felt like I was going OTB when hard on the brakes. Ended up with a 130mm stem which sounds whacked, but remember I am 6'5".
The only other thing I might suggest is a Kenda Nevegal front tire. The Velociraptor is one of my favorites, but the Nev has it beat IMHO for the riding I do.
Actually, just the opposite is true. A shorter stem allows you to get your weight off the rear more, though. I would not suggest a longer stem, though, as longer stems make riding the bike aggressively a bit more difficult.
Although I don't know how your bike is set up, I'm betting that you only need to adapt your riding style to the bike.
Got it. I'll give your tips a shot on Saturday. Thanks :wave:.
63,932
979,882
16,223
stardustmlv
