How do you wash your bike?(merged)
Discussion in 'The Workshop' started by lukewiens, Sep 4, 2007.
How often do you wash your bike?
  1. Never
    8.3%
  2. After Every Ride
    12.1%
  3. When It Needs It
    57.8%
  4. Random
    21.8%
  1. Bryguy17
    Bryguy17 A little Shaggy
    Fullerton, CA
    if i get my bike all muddy, I'll rinse it with a garden hose. just water, and use my hand to brush off any solid matter. you just need to avoid spraying into the areas with bearings (hubs, headset, BB, suspension stuff).
    then I just dry it off with an old towel and its all good...
    I would assume you can substitute a soft nylon brush for your hand as well, but whatever you've got should work fine...
  2. Ladd Jasper
    Ladd Jasper Full speed, half blind
    Russia, with love
    I've washed my bikes with a hose and dried them with a compressor for years without issue. It only takes the slightest common sense to use them both correctly and effectively to clean a bike.
    A little dry lube shot into the pivots and derailleur links chases out any stray water, and removing the chain for a Simple Green soak then blowing it dry keeps it looking and running like new.
    A couple times a year I'll break the whole thing down for a full bearing inspection/ overhaul, but most of the time it isn't required and I just end up giving it that much more thorough of a cleaning.
  3. vlad
    vlad Montrose Bike Shop
    La Crescenta - Montrose - Glendale
    WATER IS NOT BAD FOR BIKES, or any of the parts. Look at all of the pro mechanics. They use water.
    Water is not bad for bikes or parts. PRESSURE IS BAD. Its the pressure that breaks seals and allows water or dust to reaches into the nooks around cable housing, etc.
    Wash your bike with a regular water hose and no pressure head. Use a good bike cleaning shampoo like Muc Off or Finish Line's pink stuff.
    The do not use pressure goes for anything pressurized. Do not use AIR Pressure either to take out dust from hard to reach places.
  4. afgenkuong
    afgenkuong Guest
    Err... Just recently hosed off my bike and getting kinda worried that I may have sprayed water into the BB and the pivots of my bike (main concern). What should I do to make sure the pivot bolts don't rust? Not worried about shifter cables cause I'm replacing them soon. :D
    Maybe flip my bike over and give it a good shake to see if any water comes out of the seat tube?... Iono if water got inside the frame. Does a frame have any type of drainage system?....
  5. jeepr84
    jeepr84 Member
    Orange County
    I have never had an issue with using a garden hose with a little common sense. The only time I had any problems with water was, years ago, after submerging my BB multiple time on a ride and not pulling the seatpost and flipping the bike (to let the water come out) or pulling the BB. Since then, I run a small hole in my BB and have had no issues. If that freaks you out, you could always get one of these valve "thingys"....maybe the ticket if you're in a real wet climate.
    The Dry Valve was designed to eliminate water contamination of the BB bearings. It is inserted into the bottom of the bottom bracket shell at the lowest place in the bicycle frame, were the water collects. Includes valve insertion tool. Weight: 2 gr.
  6. victor13
    victor13 New Member
    I've attached pics to the first post to show you what my bike was looking like after a roll in the mud.
    P.s. Please dont make fun of my light. :p
  7. j3rmz
    j3rmz New Member
    How to clean your bike
    Just wanted some opinions on how to clean my bike and how often? I found a couple of google links and searched STR but didn't see anything about this. Is there a downside to just hosing the bad boy down and then lubing the drivetrain after? I found a dozen different approaches, but just wanted to see what you seasoned veterans think. Opinions?
  8. tweasol
    tweasol New Member
    Trabuco Canyon
    I usually just wipe it down with a rag and use an air compressor to blow out most of the crud inside the drive train - and get the chunky stuff out by threading a rag or using a toothbrush.
    If it's THAT BAD, then I disassemble and clean the individual drive train parts separately.
    Then I just get a rag, squeeze the chain and run it though there a bunch until it looks acceptable. Then lube it up. Occasionally, I'll use degreaser on it with the Park tool Tornado thing. Disposal is bad for the environment and most of the time not really necessary though (so that's rare)
    Hope that helps
  9. biknpam
    biknpam Member
    Since I will be cleaning my bike tonight.... I generally don't use a hose... if you do, its best just to lightly sprinkle the bike until the dirt/mud washes off - no power nozzles!!! You can wreck your bottom bracket etc. What I generally do is allow the mud to dry and I then use a clean cloth and a bucket of water and generally sponge the dirt off. I then dry it thoroughly and use Lemon Pledge to wipe down the frame. If the bike is really dirty I will take apart the crank and clean it and the chain. Nothing else needs to be lubed except the chain and possible where the pedals connect to teh crank. I like to use ProLink but everyone has their favorite lube. Be careful when wiping down the frame as you can scratch it. Just remember to use TLC...
  10. bing!
    I use my car cleaning brushes and turtle wax soap. I had them already, works good and fast.
    I dont blast the car with water, just a sower, and dry in the sun.
    I clean a few times a year, unless muddy.
  11. zman
    zman WTF ?
    Just dunk that thing in a river and wd-40 the moving parts :lol:
  12. N4th4n
    N4th4n Its a purse..oookkkkkkaay
    Thousand Oaks
    Hose, spray the crap out of it. Then lube the drivetrain.
  13. UPSed
    UPSed SPECIALizED
    Simi Valley
    Same here. I'm just careful not to spray directly at the BB and pivot areas.
  14. da big hills
    daily night grind
    Conejo Valley
    you guys clean your bikes? It will just get dirty again Wednesday night
  15. vlad
    There is a big misconception that washing your bike with water is somehow bad. Water is not bad for your bike, pressure is! Water pressure or air pressure - both are bad becuase they can break the seals on your suspension. Riding your bike around wih a dirty drive train is equally as bad as it leads to higher wear and tear of the drivetrain components. Plus poor performance. Try riding your standard climb with a freshly clean chain vs a dirty chain.
    Best way to wash your bike:
    - put it on a bike stand.
    - hose it down with water (either without a head or on the low "shower" or "soaker" setting.
    - spray it all over with finish line's or muck off's pink bike shampoo
    - with a bike specific degreaser and a small brush (old toothbrush) clean the cassette and the entire drive train.
    - buy a chain cleaning / degreasing tool. Fill it up with bike chain specific degreaser and roll the chain through it by turning the crank by hand at least 50-70 revolutions.
    - water it diwn again to ge the degreaser out.
    - let the bike air dry thoroughly. If you really want to make it showroom shine you can wax the frame with bike polish.
    - thoroughly lube the chain (chain only!). Let sit overnight. The following morning run the chain through a rag so that you can take all the excess lube off.
    Result is a showroom, world cup racing ready machine.
  16. 2wheel_lee
    2wheel_lee Active Member
    North Orange County
    I basically do the procedure Vlad mentioned almost every ride, although not as often on the singlespeed, since it tends not to get as dirty. I think I spend no more than a total of 5 minutes each time.
    The big downside to this is that I will admit that you may have to a quick service to Chris King hubs every 3 years or so.
  17. Silver
    Silver New Member
    Yeah, people are way too paranoid about water. Ever seen a ProTour mechanic clean a bike? There's a lot of people here who would be running up and telling him how stupid he is, I bet :D
  18. culturesponge
    culturesponge keep on keeping on
    i don't like to hose down our trailbikes anymore & think its a fastrack to a creaky bike
    instead, i let the mud dry-out & then knock as much off as i can, then i use brushes to remove most of the remaining muck, then wipe down the bike with a damp sponge & dry with a clean workshop towel before finally finishing off with a thorough drivetrain clean & lube & also clean the sanctions
    process is very boring takes time & patience - but i like to look after our bikes really well
    disclaimer:
    if we still lived in England & rode in mud & cow poop all winter long - i would just rinse the bikes down immediately post-ride & expect to overhaul the pivots & bearings more often ;)
  19. Lovin
    Lovin Calmer 'n you are
    Every 3 years...........what an inconvenience. lol
  20. Varaxis
    Varaxis Trail Ninja
    I.E.
    I used to wash my bike a lot, especially when I lived in upstate NY, but now I just wash on rare occasion. Wet it with a garden hose (no pressure) until most of the thick dirt is gone, wipe it down entirely with 3-4 paper towels, use 2 of the used paper towels after they dried a bit to wipe all the crap off the drivetrain. Lube the drive train and use the remaining 1-2 used paper towels to wipe off excess lube off the chain after working it in.
    Wiping the excess chain lube after working it in helps keep the drivetrain super clean and has no ill effects on shifting performance/noise from my experience.
    Lemon pledge optional on frame, rims, fork lowers, etc.
