Wow, can I bring my bike over?I keep my bikes meticulously cleaned. Because of where I live it's a pain in the ass to hose it down so I use more of a "dry" wash. I do this as a pre-ride ritual.
I wipe everything down with a shop rag. I mean everything. I have a Park Tools brush that gets into the crannies of the cassette and other tough areas like that. I focus on the keeping the drivetrain totally clean (what's the point of X0 and XTR if you treat it like dogsh!t?).
After that, I use a dry lube on the chain and spray lube on other parts like the bearings, etc. I wipe all that stuff down with another shop rag.
Finally, I finish the bike with Bike Lust. I apply it to most surfaces including the side-walls of the tires (NOT the contact areas though). Not only does it make the bike look good, it sheds dirt a bit. For obvious reason, don't let this stuff get on your braking surfaces.
About once every two weeks I supplement this treatment by doing a wet wash with water, Finish Line cleaner, chain wash, and special treatments for my rotors. Sometimes, a proper degreaser is in order for the drivetrain. There is a paper product called "Rags" that work very well for wiping things down and for drying. Well worth the few bucks they cost. Good brushes are also key.
Sounds a little much, but I like my stuff to run good and look good. If you're a racer and you are looking to become sponsored or already are, it's important to keep your bike and you kit working and looking good at all times.
I brush the dirt off once a year whether it needs it or not
Really.....I dry brush the dust and dirt off probably only two or three times per month, but I clean the drive-train and check the brake cables after each ride so I know it's ready to go for the next one.
There's just something inherently weird about a clean and shiny mountain bike.
See ya on the trails
Just look for the old man on the dirty bike!
No hoses get pointed at our bikes. I learned that the hard way with water in my headset that forced out the grease. That's bad.
I'm with Rob.I never use a hose.Damp rag and/or a brush to clean the dust/mud off.Clean the chain,der.,and gears with a shop cloth and re-lube chain.In So.Cal.you shouldn't need to wash or spray your bike,unless you keep them in your house.Just my.02 worth.- LloydI never hit any of my bikes with a hose. Compressed air and then a damp rag with warm water if there is crusted mud on it.
Try"Pam"cooking spray.Spray it on a shop towel,then wipe it on the down tube,back of forks,seat stays,etc.Mud comes off very easy.I never wash my bike... I like Mud all over it.. :lol:
I've seen a few people use armor all wipes though, cleans the bike pretty nice and doesnt make a mess.
Once or twice a week I would Hose it down (shower setting) brush then wipe then disassemble my bottom bracket (its not that hard) re-lube then re-assemble, even my rear der. pulleys are disassembled as well for cleaning and re-greasing. I don't hose the top part like the Head-set area and seatpost area, they only get dusted off or wiped clean.
