hope hub
RIDE 2 LIVE
fritz the dog
Mar 28, 2006
159
YORBA LINDA
i have hope hubs, and the rear hub is loose! its part of the hub that the cassette slides on to, is loose, you can wobble it? otherwords, if the wheel was off of the bike and you grab the cassett you can wobble it a little bit? any ideas?:confused:
Loose cassette
Is it the cassette that's loose or the freehub? If it's just the cassette, you can tighten the nut that holds it on. You will need an inexpensive special tool or a quick trip to the shop. If it's the freehub, I'm not familiar with Hope hubs and can't help you there. I'm sure TURNERob (should have changed his handle to Turnertuner) will pop in to lend his expertise.
C
just aks frizty
jon that thingy that the casset is mounted to is called the freehub body.ifn its the same mounting as shimano youll need to take out the axle,and titen (tighten ok mr j?) the bolt inside the f/h body.u need a 10mm allen rench(wrench). OKAY?:beer: oh thats fritzy.
63,934
979,889
16,214
hotrod4x5
