Home made bike rack
Discussion in 'General Discussion' started by jfsh, Mar 29, 2008.
  1. jfsh
    jfsh chainsaw and shovel
    teacher
    Kernville
    I've been working on a new bike rack. I wanted something that was easy to load. I got a few ideas and started welding. This is what I came up with.
    It can hold 4 bikes. I used 3/4" square tubing.
    If I remove these 2 bolts it becomes a 2 bike rack.
    I loaded it up with 4 bikes and drove it around a bit. Nothing fell off so far. The bikes don't wiggle much either. We will do further testing tomorrow.
  2. faded1004
    faded1004 New Member
    Mechanical Engineer
    LBC
    looks similar to the public bus bike racks?
    how are you going to hold them down?
    looks great!
  3. jeffj
    Bloated Mountain Biker
    Castaic, CA
    This is too easy
    Niiiiiiiiiiiiiiiiiice rrrrrrrrrrrrrrrrrrrack! :bang:
  4. foofighter
    foofighter Ride More Talk Less
    Aliso Pendejo
    +1 how do you hold down the rear?
  5. 92se-r
    92se-r Active Member
    Electrical Engineer
    San Diego
    Wheelbase is too short on the rack. Extend it out so even a short wheelbase bike or long wheelbase bike can sit inside instead of sitting on top like the Cannondale is right now. I made a rack similar to this. However, I finally broke down and bought the Performance 4 bike one because I could slide the wheel trays so when handlebars conflicted, I could adjust it. Nice home made rack though. Looks good.
  6. jfsh
    teacher
    Kernville
    I just use a cam strap. I put the strap on so it pulls down and forward. That pulls the front tire further into the hoop. I will probably put a strap on the front wheel as insurance on a long trip.
  7. dstepper
    dstepper Over the hill
    www.themostprogram.com owner
    Jeff is it just me? Or does that rack kinda look like your fence? Are you going to paint the rack white?
    :steppie:
  8. jfsh
    teacher
    Kernville
    It is built with leftover fence material. Very observant Dean. I think I can make anything look like a fence. I guess I have to paint it but that will double the materials cost.
  9. Bellvis
    Bellvis BUFFALO SOLDIER
    Dungeon Master
    Orange, CA
    Looks good, nice work. Im curious as to why you would want a hitch mounted rack when you have a truck bed. :-k When I had my trucks, I would just strap my bikes down. Is it that much easier to just load it on that rack?
  10. xwhoopax
    xwhoopax New Member
    North Hollywood
    my buddy with a tacoma used to how-to guide to make his homemade bike rack
    http://www.utahmountainbiking.com/bikerack/makerack.htm
    made of pvc pipe
    kind of pricey. but his dad is a contractor so he got most of the pipe from his dad's leftover.
    it works well. and if the pipe ever breaks, which it hasnt yet, you just shove a pipe the diameter of the hole inside to hold the broken pieces together and put some glue. bam, stronger than before!
  11. mtbmichael
    mtbmichael New Member
    student
    very nice. looks pretty sturdy and solid. how much was the cost of materials?
  12. jfsh
    teacher
    Kernville
    Good question. I do quite a bit of shuttling where we carry more bikes than I can fit in the back of the truck. Also, when you go on a trip it sure makes packing easier when you can hang the bikes off the back. They take up a ton of space in the bed.
    On this project I have spent $6. All of the steel is left over from another project. If I had to guess I would say $40-50.
  13. CalEpic
    CalEpic member
    Laguna Niguel
    That looks great Jeff. One thing I noticed. I would be carefull of the wheel trap hanging down below the rack on the back bike(s). Especially when going up/down steep driveways, etc.
    My Sportworks rack is nearing the end of it's life and I've been eyeing a welder. I think you mentioned you have a 110v wire feed. Is that what you welded this rack with?
  14. jfsh
    teacher
    Kernville
    That is something I am a little concerned about as well. The front tire does hang down a little but is not the lowest thing. The bottom of the hoop is lower so it will scrape well before the tire will. Also the back 2 bikes are 2 inches higher than the front bikes. This helps with dragging and with handlebar/seat conflicts. My driveway is pretty steep as you know and I was able to back up into the driveway with a few inches to spare.
    I welded this up with my 110v Miller 135. I use CO2 shielding gas. That little machine kicks butt.
  15. Happy_Gilmore
    Happy_Gilmore Blood Donor - Give Life
    Really nice work Bro !
  16. tkblazer
    tkblazer Zack Attack
    that looks nice Jeff, but it doesn't look 29er friendly to me :protest:
  17. danophoto
    danophoto New Member
    Saw Jeff's rack today. It's pretty sweet- stiff from side to side with good clearance...
    :bang::bang:
  18. guero
    guero iFroth
    is there anything that you can't make? sounds like dan'o really likes your new rack...what does melanie think of it? lol
    looks nice duder!!! :bang:
  19. jfsh
    teacher
    Kernville
    That is an interesting question. I don't know how a 29er would work on there. I didn't even consider it.
  20. gooseaholic
    gooseaholic Active Member
    Auto inspection
    Orange,ca Via Seattle, WA
    Looks good.Square tubing, not the usual. Is it heavy? I used to build racks for a landscape company and they weighed a ton for what they wanted.
    Oh and the bracing on the underside, do you think a good gusset would work to cut down on weight?
