royta
New Member
Fo. I've got a 1996 Mongoose IBOC Pro-SX frame (Ritchey Logic tubing) that I built up as a geared bike in 1997. It's now back to frame status, and I'm thinking of turning it into a SS for riding around the neighborhood with my kids, and bringing along on the vacations where I might do a short ride or two. I like the idea of running an Eno Eccentric hub because it will go well with my existing White Industries Tracker front, and I'm afraid to use my White Industries Ti Cassette hub with spacers due to the aluminum splined free hub body. For cranks, I'm thinking of just running what I used to run on it. Race Face Turbine LP standard drive. What chain ring do you recommend to fit 110 BCD? Right now, the frame does still have the '97 Judy SL fork. The frame is designed for suspension, but 1996 forks and I'm thinking I'd even be pushing the geometry with an 80mm. Does anybody make an inexpensive rigid fork that would work well for an older frame? Any other suggestions? Thanks.
