Has anyone ever been killed
Discussion in 'The Pub' started by chubacabra, Jan 22, 2015.
  1. chubacabra
    chubacabra Threapy Dog
    ...by something that they have purchased at HARBOR FREIGHT? Just wondering......
    There's an angled 4.5" grinder for $9.99. I can just see myself using it and all of a sudden the wheel shears off the shaft and flies into something or someone. Plus they have a complete pneumatic 10" tire/wheel for $3.99, I'd hate to think of any small trailer disasters.
  2. bing!
    I have one of those angle grinders. I'm still alive :)
  3. Heyitsdave
    Heyitsdave Member
    Fullerton
    Almost, myself. Their 20.00 cast iron bearing splitter, failed while pressing gears off a shaft from a manual transmission I was working on at home. I bought the 200.00 forged bearing splitter from Snap-On the next day at work.
  4. FD Pezman
    FD Pezman Member
    Smooth Operator
    Lake Forest
    I used to work as a fabricator on a military installation in ocean side working on very very expensive things, mind you these things cost 250 million plus. Almost everyone used those 9.99 right angle grinder from harbor freight, they last about a year with proper oiling then you just toss them and get a new one. only issue with them was the locking nut would come loose and spin off that holds the head on, just lock tight it and your good.
  5. doublewide
    King
    DTF
    But your neighbors dog is not.......
  6. bing!
    Seriously, I had to cut a small section of rebar that jutted out of a cement block in my yard. This was the most practical thing to do. Buy it and chuck it. Surprisingly, I've had it for 3 years and it works for when I need it (cutting locks, smoothing steerer cuts). If you use an angle grinder for work, or will be unsafe with a power tool without a kill switch, Harbor Freight isn't the place to go :)
  7. leondelmonte
    leondelmonte Member
    The O.C.
    ive purchased many things from harbor, my advise is use common sense and caution, what ever it is that you buy, inspect it before using it, just to make sure everything seems well in place, and dont expect it to last a lifetime, I got a drill there for $15 3 yaears ago, and that thing is still going great,
    I once got a set of screw drivers from there too, there were like 10 in the kit, but some didnt last very long, but once again only paid like $5
  8. 92se-r
    92se-r Active Member
    Electrical Engineer
    San Diego
    Dont get the spring compressor. That will kill you. Most other things are just fine.
  9. OCMoto
    OCMoto Member
    Nerd
    That's the truth! Rodgerdodger and I were swapping springs on my Tacoma a couple of years ago using one of those. Suddenly we heard a loud pop and a small retainer piece flew across the garage, the pin was barely staying in. Talk about several minutes of sweating it out backing the tension off slowly and then lots of "holy sh!t" laughter.
  10. hill^billy
    hill^billy KICK YOUR OWN A$$!.......
    rug sucker
    Acton
    I was almost killed while walking in by the stench of China! Next time you walk in, notice how TOXIC is smells in that place!
  11. chubacabra
    MAXXIS HOLY ROLLERS, you are right!!!! It does smell awful. BTW--there's a 99c Store near me that almost smells just as bad. Thanks for the tips, I'll stick to cheap flashlights and stuff like that at Harbor. Its a sad state of the world though that people feed into the cheap tool machine and in turn, they continue to churn out crap. Reminds me of the rotation on KIIS FM
  12. Shu
    Shu Active Member
    Semi-Retired
    Orange
    Do you want to buy and use daily (heavy use) or just from time to time (light use) if it's that latter then you would be good w/ cheap version....if not then buy one that will last for a long time under heavy use....
    I bought a jig saw that was very inexpensive b/c I use it 1-3 x's a yr....if I was using it weekly or multiple times a week then I would buy a better more durable version....
