Ghetto Style! Gorilla Tape Vs. Stan's Rim Tape (Before you go tubeless read this!)
Discussion in 'The Workshop' started by trailninja, Jan 2, 2013.
  1. melster
    melster Member
    Software
    Ladera Ranch
    Once you've gone tubeless, you won't go...umm...what rhymes with tubeless?
  2. OMR
    OMR Old Man Riding...
    Realtor
    Marietta, Georgia
    FYI: A little trick I picked up from Stan is to tape the rim and then put a tube in and tire on and pump it up for an couple of hours, then take the tire and tube off and the rim tape adheres perfectly to the rim... then put the back on and pump it up until the bead(s) set, deflate , add Stans and re pump... works everytime....
  3. dburdett
    dburdett Member
    www.dbMediaGroup.net
    Orange County, CA
    I'm not that patient. I just do it all in one go. Tape the rim, install tire, add sealant & inflate. Done.
    I did try the Gorilla tape on an old pair of tubed wheels when the stock rim strip failed. I never had to remove it.
  4. hill^billy
    hill^billy KICK YOUR OWN A$$!.......
    rug sucker
    Acton
    Love that simple tip. Tires are to me, the most important part on the bike, car or whatever. I am willing to spend the extra time for more piece of mind.
  5. Rossage
    Rossage Active Member
    Once you go tubeless, you'll never go boob-less! Sounds good to me!!!
  6. bing!
    if you use sealant, almost any tape will do. think about it, if sealant will plug a punctured tire, it will plug leaky tape seams.
    gorilla tape is a good choice. its tough and sticks well. i see no reason to double up. all youre trying to do is to prevent the air from escaping thru the spoke holes. one layer will do.
  7. solislbc
    solislbc Member
    Senior Finance Analyst
    Cerritos
    I've had luck slicing a 20" bmx tube down the middle and stretching it over a 26" wheel. it gives you a good seal and you have a solid valve set in place. You might be able to stretch a 26" over a 29" wheel. After it seals up, cut the remaining tube away from the tire bead.
  8. dstepper
    www.themostprogram.com owner
    Why complain about sticky residue when you are just going to lay down a new layer of tape? I remember when we used to have to coat the insides of tires with rubber cement to get non tubeless tires to seal.
    Dean
  9. bing!
    and is there anything messier than old stans :)
  10. irv_usc
    irv_usc Active Member
    Anaheim Hills, CA
    Old stans isn't bad if you leave it long enough, it's just dried up stanimals...
  11. trailninja
    trailninja Going Slideways!!!!
    Quality Engineer
    Orange County CA
    LOL fair enough you win!
  12. trailninja
    Quality Engineer
    Orange County CA
    Uberness rhymes with Tubeless....:)
  13. redwoods
    redwoods Active Member
    teacher
    Rialto, CA
    No offense, but I like Rossage's answer better.
  14. Canyonguy
    Canyonguy New Member
    Teacher
    Fullerton
    Weight weenies- just put stans in yer tubes- done
  15. UPSed
    UPSed SPECIALizED
    Simi Valley
    Unless you get a pinch flat.
  16. Mikie Watson
    Mikie Watson Member
    Mountain Bike Forum Owner
    Lebec, California
    +1 on the Pure Pork Rossage Slogan...
