mrpoonerson
New Member
I was just wondering the pros/cons of using dual crown forks vs single crown forks? :?:
mrpoonerson said:is the turning radius greatly affected on the double crown forks due to the shock conflict with the top tube?
FXRob said:mrpoonerson said:is the turning radius greatly affected on the double crown forks due to the shock conflict with the top tube?
Correct.
Are you thinking of putting a dual crown on your Giant? That would be way overkill, there are plenty of long travel single crown forks out there if you're just looking for more travel. I've got a Sherman Breakout plus on my AS-X which is a single crown w/ 7" of travel and it is just as stiff as the dual crown Super T I've owned in the past. Plenty of stuff to choose from these days, even 8" travel single crowns out now.
