1_fez_rider
New Member
- Joined
- Nov 22, 2006
- Messages
- 33
- Reaction score
- 0
Hey guys,
Don't know if you saw my message on MTBR. But I'll be getting a new Fezzari Alta Peak pretty soon. I wanted to show it here and get everyone's opinions.
It's got some of the same parts that you'd see on bikes like Trek, Giant, KHS and others.
I plan on riding this baby in Aliso Woods, Turnbull Canyon, Fullerton Loop and where ever my car can take me.
The bike is about $900.
Here are the specs:
Frame Fezzari® Racing Design Technology, Premium Aluminum frame, sealed cartridge bearings, 100mm travel, replaceable derailleur hanger, water bottle bosses
Rear Shock RockShox® Ario 2.2. 3-way adjustable with preload, external rebound adjust and lockout. Can be tuned specifically to rider weight and riding style.
Fork RockShox® Tora 302 100 mm travel. 3-way adjustable with preload, external rebound adjust and lockout. Can be tuned specifically to rider weight and riding style.
Headset Fezzari "Deep Cup" design, black alloy with oversize bearings
Stem Aluminum 4-bolt, TIG welded, anodized black. 17-degree rise.
Handlebars XC mid-rise bar, 30mm rise, 590mm-630mm width, shot-peened anodized 6061 alloy, black
Grips Velo® MTB grip, black, double density Kraton
Brakes New Avid Juicy 3 hydraulic discs, 160mm rotor
Brake Levers Avid Juicy 3 adjustable reach. New smoother operating function.
Front Derailleur Shimano® M-530 Deore, 34.9mm clamp, top pull
Rear Derailleur Shimano® RD-M761 Shimano XT
Shift Levers Shimano® M-511 Deore Mega 9 STI Lever Set
Cassette SRAM® Powerglide II PG-950 upgrade 11-34T, chrome plated
Chain Shimano® HG-53 Super-narrow, 9-speed, 11x34t
Crankset Truvativ® Blaze Power Spline, all-mountain, aggressive cross-country, forged 1-piece
Chainrings 44Ax32Sx22S, 4-bolt 104/64mm pattern, replaceable chainrings
Bottom Bracket Truvativ® Giga Pipe SLLT Power Spline, sealed cartridge bearings & CNC’d steel cups
Pedals BMX-style Fezzari Racing flats. Aluminum, CNC machined Cr-Mo axle, sealed bearing.
Rims Mavic® XM117 Disc. 15Gx32H alloy, diamond-shaped doublewall, black anodized
Front Hub Fezzari disc, 32 hole, high-grade loose ball bearings, alloy Quick Release
Rear Hub Shimano® M-475 disc, 32 hole, loose ball bearings, alloy Quick Release
Spokes 1.8mm (15g) black stainless, brass nipples
Tires Maxxis® Larsen TT 2.0 World Championship Tires
Saddle WTB® Speed V Comp with high padding
Seat Post Alloy, blast black, 31.6 x 350mm
Seat Binder Alloy, black anodized, 34.9 mm Quick Release Clamp
Here are the specs:
