Flat Broke
Bikes don't kill bunnies
I was out at the Oaks yesterday evening when I noticed my rear brake lever was starting to get a little stiff. Then about 5 or 6 pulls later, the lever wasn't returning and the brake was staying locked up. I was able to mannually return the lever to it's normal position, but needless to say, comming down with only a front brake was a little tedious to say the least.
The cables/housings are new with maybe 4 rides on them, they've been adjusted once after they stretched and at this point I'm a little perplexed. Basically it's like when you pull the cable, it's grabbing on the housing then not returning on the way back. If I cycle the caliper without the cable, it feels smooth and returns fine. The lever moves freely without the cable installed, and the cable seems smooth in the housing with no resistance against it. But put em all together and they deffinitely aren't working right. I haven't taken any large bails that would have stuffed dirt etc down the cables, and the front that got quite a workout last night is running the same cable/housing and is working fine. I checked for kinks or creases from the cable management clips and everything is fine.
Before I go throw down for some straight jackets or something, does anyone see anything obvious that I missed or know of similar problems?
Thanks,
Chris
Thanks,
Chris
