And on the 13th Day .....
TurboJared
Overstimulated
Dec 15, 2005
852
Rancho Belago
Yesterday i tick off day number 13 of riding to work. I was on the 295 commuted mile. and what did Torrance give to me ...
A FREEKING SCREW.
http://img167.imageshack.us/img167/8268/1000260vb0.jpg
How'd this get that far in anyways?
DANG! That's crazy.
Have you considered commuting on smoother tires? I use Continental's Town and Country tire. It's basically smooth with a little tread. The best thing about it is that it has three plys and a Kevlar layer. Oh, and they're $15 at Performance right now. I also have a Mr. Tuffy liner in there with thorn resistant tubes. Yeah, it's probably heavy, but it's only 7 miles each way and it only makes me stronger. Plus, I ride through all kinds of glass and metal and I haven't (knock knock) had a flat yet.
Performance.com And, oops, I was wrong, they're $20 now. I got them for $15 a few months ago.
I ride a Trek 830 (ca. 1994) with 26" rims. There's a commuting thread in the Water Cooler forum with more info on the bike if you want to know.
Bret, you should try some Robitussin or something 'cause you gots a bad cough, yo. ;) I've seen that cough in several threads now. You should get it checked.
And, isn't Stans more of an off-road thing? I always thought of it more to remedy snake bites due to low tire pressure. Am I wrong? (It happens occassionally.)
Glen, I snagged this from the Stans site:
Features and Benefits of Stan's Tubeless System
Stan's Tubeless System offers two sealing points on the tire versus other tubeless systems which use only the bead lock as their sealing point. First the bead lock is sealed, as well as the lower portion of the tire and rim to create a second inner seal. This unique design allows you to break the bead lock seal without losing air pressure. Secondly, the inner seal flexes inwards with the tire to maintain air pressure (see above photo).
The patented Rim Strip makes installation simple. It can be removed as easily as a tube and can be used over and over again. Time involved can be less than 10 minutes per wheel. With this system you can lose rotating weight in an area that previously was not possible.
Your lightweight wheel set can be converted to a tubeless set up with only 56 grams of added weight per wheel. Saving hundreds of dollars over purchasing new wheels.
No need to worry about the dreaded pinch flat.
Possibly never having another puncture flat again because of the self-sealing qualities of Stan's Tire and Rim Sealant.
You will be able to keep using your lightweight tires and not be limited to buying expensive and much heavier tubeless specific tires.
The New Molded Rim Strip features a new Presta valve stem with a removable core allowing you to add sealant without removing the tire. This removable valve core will make inflating easier by increasing the air flow into the tire. Removing the valve core also allows for cleaning or easy replacement.
Stan's Tire & Rim Sealant can also be used to seal punctures and slow leaks that occur in most tubeless tires. As a result, your tubeless tires will hold air for longer periods of time.
Other Information
If you are interested in rotating weight (and who's not!!) you can lose anywhere from 100 grams up to 400 grams of rotating weight per wheel set.
This System does not require any modifications to your existing wheel set. If you are not satisfied with it, all you do is remove the rim strip, and put your old heavy tube back in and go riding.
This System requires very little mechanical ability to install.
It does not use any glue and you can change a flat the same way you do now.
Lower Air Pressure, Better Traction and Ride
Stan's Tire and Rim Sealant will usually last from three weeks up to three months. At that time you simply add more. (Time will vary due to different tire characteristics). It leaves no mess in your tire.
Stan's Tire and Rim Sealant can also be used in tubeless tires for puncture resistance and STOPS leaks.
Once you seal your tires they will not lose air pressure.
What happens if I get a flat on the Trail? -- Do like most riders, and bum a tube from one of your pals because they always carry one. Heck, use their pump too!! Stan's Tire & Rim Sealant does not use any glue, so you can change a flat the same way you do now.
no stans for a commuter... it's all part of the fun. besides isn't it pretty expensive? Get some heavy duty slicks like gurp said.
Yeah, I gotta say after reading that Stan's info that it seems to be directed primarily at trail bikes. It doesn't say anything about high pressure road tires. For a commuter, you want pretty high air pressure on your tires to decrease rolling resistance.
I use slime in my mountain bike tubes. They only patch certain punctures, though. Glass and snake bites don't get sealed.
So, I remain unmoved as to Stan's on my commuter. However, for my trail bike, I'm going to keep it in mind. I had always thought you had to have special rims and tires. But, according to that, no. Hmmm.
For a commuter bike I was running some Hutchinson Pythons at like 65 - 70 psi. They were great on asphalt and slickrock but scary on most everything else.
63,934
979,889
16,214
hotrod4x5
