SRAM X7 Shifter rebuild - i F** up
Discussion in 'The Workshop' started by jton219, Jun 3, 2013.
  1. jton219
    jton219 Member
    Banking
    So my Stumpy wasn't shifting well in the rear. I changed the cable and housing. When i opened up the shifter, saw some dirt and gunk in there. felt like i had to take it apart, clean it out and relube it. Did all that, and when i put it all back together, i had 1 part leftover. Pic below.
    WHERE DOES IT GO???!??!??!?!!?!??!
    Looked on SRAM site for parts list schematic, its not there, checked a few other forums that had some rebuild guides but the internals look diff. They were for 9spd XO and X9 RDs. Youtube also had a vid i watched but i don't see the part that i have left over.
  2. leondelmonte
    leondelmonte Member
    The O.C.
    I think that is the trigger spring, I will take mine apart when I get home tonight
  3. eatsrice91
    eatsrice91 NoMoSoCal
    Yes
    Madison Heights, VA
    ^^agreed
  4. jton219
    jton219 Member
    Banking
    Anyone got a screenshot of the correct position for the spring. It fell out before i ever got a look at where its suppose to go.
  5. digitaldouble
    digitaldouble Member
    Architect
    Ventura County
    Did something similar with my X9 shifter, but luckily no "spare" parts leftovers...:)
  6. destroyer
    destroyer I build jumps
    Hesperia
  7. thomaswildchild
    thomaswildchild Active Member
    I am a Machinist
    Fullerton CA
    i believe thats the smaller lever return spring. to shift down gears.
  8. palom0
    palom0 New Member
    BTW, you know you don't need to unscrew anything to replace the cable, yes? You just pry open the rubber cover (in your pic) with your finger and insert the cable through that hole. No screws, nothing. Hope it helps next time!!.
  9. jalayu
    jalayu New Member
  10. jton219
    jton219 Member
    Banking
    Just in case anyone else gets stuck like i did. here is a pic of where it goes. The trigger has a axle that it moves on. where the trigger housing goes around the axle, there is a small groove for the spring. Trigger spring.jpg
    Thanks everyone.
