Freeride Last Weekend at Keystone, CO wrap up (Part 1)
Discussion in 'The Adrenaline Factory' started by mouse jockey, Sep 6, 2008.
  1. mouse jockey
    mouse jockey i can't type the letter s
    molecular researcher
    Just outside of La Jolla
    On the way up....
    [​IMG]Rider Rider about to flow East Forest cork screw feature
    First run I had down was Milky Way -> High Speed Dirt -> Jam Rock -> Mosquito Coast -> Helter / Skelter. Wow, what a ride! I think this is my favorite ride on the mountain because it has so much variety, steeps, drops, jumps, roots, step-ups, steep switchbacks, forests in the trees, fast DH, rocky ledges and bridges, did I say it has a little of everything?
    Came down Milky Way and through the roots and doubles, dropped the steep ledge step down in the forest which sends you into a right hand berm out into the open ski area winding left back into the forest for some more doubles and drops you into a 30 yard DH fall–line open area with 3 major lines to take down.
    The line I normally take is on the right which heads down the fall line (fairly steep with rock armor underneath dirt to avoid erosion) and turns left across the steeper other major lines. Well the Thursday before I rode this trail I was eyeing these other two lines down the falls. The first line is straight ahead down a rocky traverse which is steeper and more sketch than the farthest right hand line, steep. The Middle Line looked to be the most sketch and most difficult which is of course the one I wanted to ride. I passed on Thursday, reminding myself I will lose much of my self respect if I don’t head back before Keystone closes on Sept 1st and conquer that Middle Line.
    So, here it is Monday Sept 1st, as I roll up to the rocky fall. I got off my bike and eyed the Middle Line. This particular line drops you down some steep rocks with ENDO written all over it (how much endo potential I really didn’t know since I’ve never witnessed anyone take this line) and then down into some dirt, down a portion of the trail at which point you have to huck a 6 foot drop to complete the line; if you don’t get your wheel up before the ledge you are definitely going over and fall 8 feet to the ground below and maybe farther if you don’t stop on the flat ledge below (the place where the right line crosses the other two). As I said, I’ve never witnessed anybody take this line and true to that statement there were no tire tracks in the dirt heading to that Middle Line. I was kind of waiting for some riders to come by and stop so (1) I could have some witnesses and (2) If something went wrong they’d be able to get help. Well 3 riders came by and blazed on past down the most traversed right line. I just didn’t have the heart to yell out for them to stop and monitor me if something went wrong so I decided I’m on my own.
    [​IMG]I
    I said my prayer, placed my feet on my flats, checked my proprioception, (.02 cent word meaning body language awareness) and dropped in. Well, the description takes a lot longer than the actual ride which is over in a matter of seconds. The first few rocks were fine leading into the real Endo portion which kicks the tire back into your butt, where for a moment the only thing touching the ground is your front tire, best not to get stuck here. The rear tire jumping up into my behind I had to keep way behind the seat to settle the rear down as I came in fast to the huck. Got to hit the brakes here a bit, slow things down, and get the front up, which I did with perfection and much trepidation, and huck down, make the left turn on the flat and with a hearty YEA! I manage to tackle and conquer a new line at Keystone. I did this same line 2 more times after to prove to myself it wasn’t a fluke. I also did the first line straight ahead which is a steep line down rocks with no hucks, very fun too. My self-respect intact and quite pleased with myself I continue on.
    Things continued down the trail to Jam Rock with some nice kickers in the forest and a few drops to the side of Jam Rock. Prior to entering the wood feature on Jam Rock it is best to shift down into a low gear because the technical up onto the wood feature is hard to manage if you have to mash the gears. Up the wood feature, front brake down and into the steep rocky lines.
    There are multiple lines to be found on the Rock all of which drop down into the pointy rock launch to transition into a fast left hand berm, throuch rocks and roots, down to a double onto Mosquito Coast. I hit the pointy rock launch fast, and landed past the bridge into the transition, which is a super smooth landing, down the left hand berm, stopped to knuckle bump a dude watching and continued to send down Mosquito Coast.
    Point Rock Launch to left hand berm at bottom
    Mosquito Coast is a fun and fast flowy trail with drops and jumps. This leads you into Helter / Skelter, with its first step up jump, and then down into a steep left switchback. This switchback is an armored switch that the trail care crew at Keystone obviously put a lot of time into, they did a real good job all the way down.
    I really like this section of the trail because of its winding steep nature through the forest. This leads you into an open section that drops you into a rock roll off a 3 foot drop in the trees into some doubles and a ledge launch to the open. Wow, what a ride. There is a large wall ride at Skelter’s exit before a bridge that I like to climb. I don’t think it’s meant to be a wall ride but it’s a good 25 feet high; it’s a man made cement retaining wall with undulations and bumps that is easy to climb and fun to descend. Cool.
    The next lift up I then managed to flow down Cowboy Up with its drops and roots and rock gardens. This is a fast winding trail that was my first trail at Keystone 4 years ago. This leads to Motorhead with its table-tops and fast forestry DH which then descends into Paid in Full with its Drop Zone.
    The Drop Zone has multiple drops and one heinous rock garden leading to a small ladder drop called VooDoo. I’ve never managed to clean VooDoo because you’ve got to have a lot of speed through the garden and not care too much about your stanchions. The Drop Zone consists of Piranha, a 5 foot or more drop, Barracuda, a 7 foot or more drop, the aforementioned VooDoo with a 3 foot drop, there’s another 6 foot or more drop to a wood transition, and Witch Doctor a 6 foot or more drop from a steep winding bridge to a natural steep transition with a giant G-out. The 14 foot or more drop, Jaws, has been dismantled for the season, not sure why.
    Jaws:
    I can't figure out how to embed the video of me hitting Jaws from two years ago, so if you're interested in seeing the video click the link below.
    http://www.youtube.com/watch?v=abNw5nZ0_LU
    Paranoid:
    [​IMG]A
    A bit nosey on Paranoid last year:
    VooDoo:
    I’ve managed to ride every single drop since I’ve been coming to Keystone, with the exception of Witch Doctor. Not sure why I’ve managed to bypass the Witch, I just have. So this time I wanted to ride Witch Doctor. I checked out the steep, winding ladder into the drop, and decided it’s all front brake prior to the drop. If you aren’t heavy on the front, you’ll slide off the bride very quickly. So with my technique in mind, I dropped in, rode the bridge, butt way behind my seat, came up to the drop and launched myself into the left berm with a G-out. Wow! How did I miss this one?? This is by far my favorite drop in the Drop Zone, maybe all of Keystone. I love the steep winding ladder set-up into the launch which you can extend far beyond the 6 foot minimum due to the steep transition. Lots of fun.
    Witch Doctor:
    Yippee!
    To Be Continued.....
  2. mouse jockey
    Oh, well shoot....I didn't see JT's admonition about keeping posts in the Adrenaline section less than 100 words until AFTER posting this. Hey guys show me some love here, I've been cooped up in the mountains without internet for almost two weeks with nothing to do in the evenings except drink, eat smores, and type.
    So, yea it's a bit wordy but think of me as your crazy little brother who's been hyped up on sugar smacks and coke, tied down in his car seat for 12 hours who just needs someone to say, "hey it's not your fault, you little PIA".
    (mods: please move post if I've violated terms of AF)
  3. dhmike
    dhmike Banned
    process server
    so.cal desert
    i think i just found my new home in co. awesome pics ! i just wish ss would get there sh*t together and stop hating dh because i really don't want to have to move to co.
  4. CalEpic
    CalEpic member
    Laguna Niguel
    I've just added a new place to my To Do List.
    Good stuff, thanks.
    C
  5. ArrrKelly
    ArrrKelly New Member
    Gnarly! Makes Whistler look like a bunny slope.
  6. sdyeti
    sdyeti New Member
    CA via MA
    Okay, granted, there aren't as many huge ladders to hit but...
    I really like how they put the height of the drop on the sign...smart idea!
  7. Jordansrealm
    Jordansrealm New Member
    Photographer/Editor
    Rancho Santa Margarita, CA
    I think I fell and hurt myself just looking at the huckability in those pics!
  8. Happy_Gilmore
    Happy_Gilmore Blood Donor - Give Life
    Nice report, 14' drop looks--------> insane, sign posting is a dam good idea.
  9. mouse jockey
    Whistler has more variety that I'm aware of but Keystone is really stepping up and trying to be the premier DH resort in the U.S. Even with Winter Park hosting Crankworx, Keystone is better overall IMO than WP, but not Whistler. Blackcomb is just a bigger mountain with more vert.
    The Jaws drop is 14 minimum, you could really launch into the transition and hit more than a 20 foot drop there. :eek:
  10. CA_descender
    CA_descender IamHAZZMATTseeMEgroove
    Father & Husband
    Some of that is definitely a bit over my head, literally ;)
    Nice report, another good reason to hit up CO.
    Here is your vid for the lazy ;)
    [youtube]abNw5nZ0_LU[/youtube]
  11. El Salt
    El Salt Guest
    Wow! Makes my trails and my ability look like... 8-[
    Great shots! Looks amazing.
  12. madridg
    madridg Ride Therapy Patient
    Medical Device Engineer
    Dana Point
    wow. great pics, you make the impossible lines and hucks look easy. :beer:
  13. jamisjake
    jamisjake Active Member
    Industrial Mechanic
    Menifee
    WOW!! Great riding, awesome R/R!!! I have to get to Keystone!:bang::bang::bang::bang::bang::bang::bang::bang::bang:
  14. Magna_Graecia
    Magna_Graecia Tapia Bunny Slayer
    Translator, Monkey Boy
    Long Beach, CA
    This RR has made me want to get a DH rig... and a spine! (^_^)d
    After seeing these pictures, all I can say is:
    "You have balls of steel, my friend."
  15. herzalot
    herzalot Well-Known Member
    EdgeUCater
    Great RR. I went to Keystone this summer, but they were closed due to rain and late hour. Did I see an Evo and an ASX in those pictures? Is there anything there for a guy who likes Vote for Pedro style drops (i.e. 2-4') without having to risk life and limb? Or is everything as gnarly as your pics indicate?
  16. mouse jockey
    There is a ton of stuff that a non-hucker can ride. The XC trails and Super D type Blue trails, Suze's Cruise, Girl Scout, Mosquito Coast, Eye of the Tiger, Logger's Way, TNT, and more, lots of fun! I just didn't take pics of those trails because I was having too much fun flowing each and every one of them!
    I'm still getting together Part 2 with some more ladder pics.
    Yep, I own an ASX and just put on a ROCO RC for the Colorado trip. The ROCO felt really good, both on the drops and the stutter bumps and rocks. :bang:
  17. mouse jockey
    Here is my ASX with it's new ROCO that I beat up on at Keystone.
    BTW, how do you embed a video on this site? I've tried to embed using the embedding code on YouTube but it never works for me on this site.
  18. JoeTruth
    JoeTruth Active Member
    Sierra Madre, CA
    Wow, Tom, that's a classic and phenomenal RR. If the new and only used twice RR of the week was still active (Jorge!!!!), I'd give you my vote in a heart beat. Furthermore, you're exempt from the 100 words or less RR's rule but this time only. ;)
    Nice job. Some of them lines and drops make me feel like tucking my junk between my legs and running away screaming like a little biatch. :lol:
  19. mouse jockey
    Hey Thanks Joe! I've managed to post Part 2 in Trail Talk so I won't violate 100 word rule again. :wave:
    (saying Hi from an internet coffee shop in Las Vegas on my way home.)
  20. maxwell
    maxwell Dirty Stinky PATH Love
    CRASH TEST DUMMY $#%&*^#
    Tustin
    Man, that's freak'n awsome!!
    Great RR and pics!
    Where have I been that I hadn't heard of Keystone until now? #-o
    I have a new vacation spot to shot for, for next year!
    Thank's again for the post!
