Iron Horse Bikes
Discussion in 'The Workshop' started by northshore, Oct 29, 2007.
  1. JOx2
    JOx2 Active Member
    Menifee
    this picture is worth a thousand words. "LOL" is one of them. :beer::beer:
  2. tkblazer
    tkblazer Zack Attack
    if IH only still made DJ/4x frames ;)
  3. allison
    allison Active Member
    That would be sweet, eh?
    :lol:
  4. tkblazer
    yea.... the turner 5spot 4x bike is flippin sweet
  5. Flat Broke
    Flat Broke Bikes don't kill bunnies
    Jack of all trades, master of some
    LBCizzle
    I don't have one, and I'd PM the folks Dino mentioned for insight into that particular frame setup before doing anything else. Remember that this can be a problem with any shock that doesn't have a way to make the compression dampening progressive. Depending on the year of Reign, there may not be many shock options that will fit in the hole. If you're stuck with shocks that don't run resevoirs due to space constraints, you might want to look into the Marzocchi Rocco R air(if it will fit). It's a pretty basic shock with no platform, but you can adjust it's bottom out resistance which might help in your situation. Another option would be to call the guys at Garageworks suspension, or Push and see if they have any recommendations/solutions for your application.
    Chris
  6. tkblazer
    what year and model do you have? rocco r would not be a good choice as no platform and high volume will only increase how linear the rear suspension already is. If you're running a fox shock, switch out the air can to the smallest size. Push Industries sells the small air can and new bottom out bumper as options for their tunes.
  7. alank
    alank New Member
    :lol:...great camera work..
