If you could have only one brand of hydraulic brakes, which would it be?
Discussion in 'The Workshop' started by BrewMaster, Jun 24, 2008.
If you could only have one brand of hydraulic disc brakes, which would you choose?
  1. Avid
    27.5%
  2. Hayes
    13.7%
  3. Hope
    13.2%
  4. Magura
    14.3%
  5. Formula
    14.8%
  6. Shimano
    16.5%
  1. Code Blue
    Code Blue Guest
    Point
    they are not heavy........yes I have Hope brakes and have owned Hayes, Avid and others. IMO they do not work as well as Hopes
  2. KTMRDR
    KTMRDR New Member
    Project Manager
    Eastvale
    I am running Magura Martas and I love them!
  3. Chris
    Chris New Member
    MOTOR TABS & Ladera Cyclery
    Orange County
    Me too...
    And they are so pretty and match my bike \\:D/
    Hahaha
  4. chongoblanco
    chongoblanco Banned
    none i get my check on the 1st!
    anacrime califa!
    how does 8 piston brakes sound!!
    Has anyone used these brakes before I think I might have to try these on my next bike!!
    http://www.gatorbrake.com/page3.htm
    I think 8 pistons should modulate pretty good, and you would not have to worry about brake fade.
  5. 1080P
    1080P Banned
    The 818 curtain
    I use them, to death.... still haven't killed mine yet and I started out at a plump 255#s on mine. Run the stock pads until they are used up, then go get the Kool Stop sintered metallic pads. If you weigh over 220, and do long descents, set them up with 200mm rotors front and rear, 160mm if your weight is at or under 160 pounds or you are a flatlander XC rider, and 180mm if you are in between.
    I clean out the residue crap with a tooth brush and brake cleaner around the caliper pistons with every set of pad changes, (about every 4 to 5 months for me), and apply a little Plumbers silicone lube before pressing the calipers back in to the bodies and installing new pads.
    Modulation? Outstanding
    I like the feel of organic pads on front and sintered pads in the rear, as I tend to sometimes drag the rear brake slightly to straighten things out when things get hairy.
    Most of you could probably be very happy with just 180mm rotors and sintered pads. I know I am with the 200's.
  6. BFloFoxRider.
    BFloFoxRider. Active Member
    Army
    Claremont
    DO they make smaller rotors for people that weigh 135? :wave:
    Just kidding, looks like i would end up getting the 160 rotors or 180
  7. BrewMaster
    BrewMaster Thirsty
    Chemist
    Foster City, CA
    Some brands offer 140 mm rotors for the rear.
  8. DHS
    DHS New Member
    Nerd
    La Jolla
    I've had all kinds of the brakes. avid, hayes, shimano, hope, formula, tektro, giant, magura
    and still i've come back to shimano. they are still the easiest to bleed. hell you could bleed them on the trail if needed. i've even used veggie cooking oil in a pinch. sure didn;'t work that well. but it was all we had.
    but the best combo so far, is a 07 lx/xt lever, with the straitline lever upgrade. and i like the 07 saint caliper, because of the banjo, being able to route your line the best
    anything post mounted or even IS can be 140mm rear. just use a 160 front adapter, on the rear of the bike. it'll work with a 140mm rotor.
