fork seal changes
Discussion in 'The Workshop' started by scan, Dec 2, 2014.
  1. scan
    scan Member
    occupational therapist
    alta loma
    Anybody know of good place for fork maintenance, IE area,I live in Rancho Cucamonga. Is under60$ unreasonable?
  2. wheeler
    wheeler Member
    Depending on the service but $100 is more likely if seals are needed. What kind of fork? How old?
  3. Neccros
    Neccros Technically Canadian
    Engineer
    Redondo Beach
    If your willing to drive, Steve @ Garageworks suspension can hook you up. He is in Oceanside now...
    GARAGEWORKS
    318 via del norte
    oceanside, CA 92058
    760-966-1048
  4. mtnbikej
    mtnbikej Well-Known Member
    You could always buy the seals and service them yourself.
    Both Fox and RS have pretty good info on their sites.
    That at way could be done for well under $60.
  5. Neccros
    Engineer
    Redondo Beach
    You tube is your friend for DIY repairs... Sometimes the MFG has how to videos. At least Fox does.
  6. mtnbikej
    As does RS/SRAM
  7. ejhorn
    ejhorn Member
    Grad Student in Chemistry
    Irvine, Ca
    Couldn't agree more with this. With all the resources available online it is pretty easy to learn to do this yourself. Much cheaper than having a shop do it, and it will give you a better understanding of how the fork works etc.
    Just make sure you set aside ample time to do it the first time you try, and be patient.
