Any suggestions for hanging bike on the wall?
Discussion in 'The Roadie Hangout' started by lego2000, Sep 8, 2008.
  1. lego2000
    lego2000 Member
    Wireless
    This is what I ended up getting. $6 at Lowe's and it's specifically made for bike hanging. It directly mounts to the wall.
  2. crashergs
    crashergs New Member
    Carpenter
    INLAND EMPIRE
    does it have enough clearance for your handlebars so the bars are not crooked ?
  3. epicriderat
    epicriderat New Member
    Self employed DME
    Newbury Park
    It can be mounted using the 2 holes in the bracket instead of mounting to the rail. I just made sure I hit a stud in the wall or use a drywall type anchor.
  4. MohammedInABearSuit
  5. SSinGA
    SSinGA Free-XC-Downhiller
    short-bus driver
    The South
    Lowe's and HD both carry something like this bike hanger.
  6. 2wheel_lee
    2wheel_lee Active Member
    North Orange County
    Uh...you have your front Kenda Nevegal mounted backwards.
  7. crashergs
    Carpenter
    INLAND EMPIRE
  8. lego2000
    lego2000 Member
    Wireless
    Yes, this particular hook has more than enough clearance for the handlebars...
  9. Sweetpea
    Sweetpea Member
    family law attorney
    Costa Mesa and Fullerton
    Actually, Lee, it looks like the entire wheel has been swiveled around backwards.
  10. 2wheel_lee
    North Orange County
    Do you mean as in having the rotor on the opposite side of the caliper (wheel installed backward)? Could be, but I think I see a rotor on the caliper side, but I can't really tell. Note that the caliper is on the left side of the bike, so the fork is pointing forward.
  11. crashergs
    Carpenter
    INLAND EMPIRE
    easy solution, ill be picking this up tonight...
  12. Pato
    Pato Stop stealing my thunder!
    Computer/Networking nerd
    Downey, CA
    Also note the more obvious signs, the lowers. The arch is in the front. The only major manufacturer that has them in the rear by design is Manitou. Another dead give away are the pinch bolts for the 20mm axle. They are also in the front as can be found on most, if not, all forks.
    Good catch on the backwards tire Lee. I see that so often on peoples' bikes. If you can see the front caliper, you got quite a pair of eyes there my friend. The only indication I can see is the brake line routing.
  13. SSinGA
    short-bus driver
    The South
    the nevy worked better backwards, plus the rolling is so bad on that tire that it doesn't get any worse backwards.
