All Things STRAVA (merged threads)
Discussion in 'Racing and Training' started by hawkesworthm, Dec 13, 2009.
  1. Danimal
    Danimal Gary the Cat
    Mission Viejo
    For me thats not a problem, as I have never cared if I'm ahead or behind any one ( unless they're kicking up too much dust in my face).
    Only use I've ever had for this site was to see my stats, and if I'm getting faster up a hill.
    On the internet? never happens!
  2. bvader
    bvader Long Live The Gorn!
    Tech Guy
    Huntington Beach
    OTOH if you a waaaaayyyy into stats and anlayis check this out http://veloviewer.com/ take a while to set up but pretty cool....
    BTW NOT StravA$$hole... just love data analysis and visualization
    Summary
    Activity Page
  3. rjcsocal
    rjcsocal Member
    Coastal OC
    I'm a total data junkie -- this site is such a huge improvement to the data Strava collects. I use it more than Strava. This site is way improved to where it was 2 years ago (I dug it even then).
  4. scan
    scan Member
    occupational therapist
    alta loma
    Btw does anyone know if you can change the record of your highest climb? On mine it doesn't show my highest climb. I don't get it. Has anyone else seen this on their profiles?
  5. Andy
    Andy Member
    Orange County, CA
    I have a KOM - for a segment I've never even ridden!
    Seeing the discrepancies between Strava and Map My Ride makes me wonder what else they're getting wrong...
  6. mtnbikej
    mtnbikej Well-Known Member
  7. wheeler
    wheeler Member
    Speaking of Strava........
    There are bunch of kids in my community that ride mbikes. My son and I were thinking of creating a club in Strava for them but they are all under 18. Do you have to be 18 to use Strava?
    Thanks
  8. mako my day
    mako my day New Member
    Commercial door, frame and hardware supplier.
    Aliso
  9. ericfoltz
    ericfoltz Active Member
    Photographer
    Out on the Road
    From the terms of service: "In consideration of your use of the Site, you represent that you are of legal age to form a binding contract."
  10. wheeler
    wheeler Member
    Thanks!
  11. rjcsocal
    rjcsocal Member
    Coastal OC
    I apologize in advance if the question has been raised already. Haven't kept up with the post and with over 900 responses, a bit much to get through.
    I recently bought a Forerunner since I started running a bit (one of those life/work/kids points of life that has limited my workout time). The Forerunner connects through ANT and has worked perfectly fine so far -- I actually used it on a couple rides but realized I still like my Edge 500 for riding b/c the barometric altimeter. Now when I try and download my Edge data on Strava, it doesn't recognize the device. I searched the Strava knowledge database and someone recently posted the same dilemma. Strava's response was:
    "Because the Forerunner device using the ANT USB stick, all the files transferred from the device are first stored in a local directory before they are uploaded to Strava (or Garmin Connect). The Strava uploader probably sees the old local directory from your Forerunner before it sees your Garmin Edge.
    We don't have a way to set a default device, but you could remove the Forerunner device from the ANT Agent software if you're no longer using it.
    Hope that helps!"
    Not much of a help. GarminConnect doesn't have a problem speaking with either of the devices. Unfortunately my solution now is to download the data on GarminConnect and export the data as TPX, then upload to Strava manually. If anyone out there has a better solution, I'd appreciate it. Thanks in advance.
  12. crispy
    crispy Wannabe
    Engineer
    Moreno Valley, CA
    When you click uploaded, then click th eget started button under garmin, you should see multiple devices. Just select to upload from you edge instead of your forerunner. I do it all the time.
    If that doesn't work, you can select to upload from a file and just browse to the proper directory where you garmin is located.
    If that doesn't work....make sure you have plugged in the edge unit. It wont connect through the ant+ stick like the forerunner will. If it is plugged in, unplug and re-plug. Sometimes my edge goes into an external power mode and the computer doesn't recognize it. A quick un-plug/re-plug usually fixes that.
  13. rjcsocal
    rjcsocal Member
    Coastal OC
  14. mtnbikej
  15. cruiten
    cruiten New Member
    Foothill Ranch, CA
    Strange, Garmin Connect currently works for me in both Classic and Modern modes in Google Chrome "Version 36.0.1985.125 m" on Windows 7 Professional...
  16. mtnbikej
    Same version Chrome.....but on Windows 8.1 the Modern mode doesn't work. No problem with the Classic mode.
    None of the prompts on the left work.
  17. cruiten
    cruiten New Member
    Foothill Ranch, CA
  18. me and my bike
    me and my bike New Member
    man of many trades
    The OC
  19. profnachos
    profnachos Member
    software engineer
    West Garden Grove, CA
    Sorry if this has been covered before, but why is it that when I upload a ride from my Garmin (Edge 305), it always inflates the elevation by 200-300 feet? I have to press the "correct elevation" button at which point, my elevation goes back to about what the Garmin unit says. So why doesn't it take what the Garmin says at face value in the first place.
  20. shawndoh
    shawndoh New Member
    Lake Forest
    Anyone know why Strava ditched the day/week/month leader board? I stalked... errr, met some great people that way.
