Adjustable Seatpost Longterm Durability Results
Discussion in 'The Workshop' started by Gasper, Aug 22, 2011.
  1. Gasper
    Gasper New Member
    Anaheim Hills
    After using a Joplin for about 18 months I've decided to try something with no set back and more drop. The question is, have the Reverb or the KS products improved their dependability or am I stuck with the Gravity Dropper and it's funky looking bellows and 90 degree cable exit. What do you guys and gals say?
    Thanks
  2. denmother
    denmother Gone riding....
    Female
    Riverside
    I gave my Gravity Dropper Turbo to Roger and I am now using the Rockshox Reverb and love it!!!
  3. Magna_Graecia
    Magna_Graecia Tapia Bunny Slayer
    Translator, Monkey Boy
    Long Beach, CA
    I've had the Reverb since it was released and, other than having to bleed it once, have had zero problems with it.
  4. Gasper
    Gasper New Member
    Anaheim Hills
    How long have you had your Reverb Nancy?
  5. mfoga
    mfoga Intense Whore
    Have 2 KS posts never had an issue with either
  6. denmother
    Female
    Riverside
    10 months!
  7. Revalimage
    Revalimage Active Member
    Entertainment Production
    Mission Viejo
    19 mos on a KS i900, 16 mos on a Gravity Dropper - no problem on either.
    But my next one will have the cable coming from the bottom of the past (like the GD) and not from the top of the seat. When lowered the cable sticks out a bit on the KS, it needs to have freedom to move, and hits my leg when I'm behind the seat.
  8. tkblazer
    tkblazer Zack Attack
    Four years on a gravity dropper classic and I just bought another one for my 29er. Love those things
  9. Chewyeti
    Chewyeti Circus Bear
    Yorba Linda
    Have a few posts with varying success.
    Joplin - ~1 yr. blew up twice, leaks, air pockets so the seat floats up. Grade: F
    Gravity droppers (non turbo): owned 2. ~2 years on one, works great, just ugly. Had one cable actuator assembly become un-epoxied from the post. Grade: A-
    Specialized command post: 1.5 yrs. STill kicking ass. The lever is a little wonky and uses a special cable. Seat clamp is sticky. Grade: B+
    KS 150mm post: ~3 months. still going strong. no leaks. Tends to stick in down position every once in a while. Seat clamp could be better Grade:B
  10. Gasper
    Gasper New Member
    Anaheim Hills
    I'm going to respectfully say that if it can withstand the "demands" that Chewy puts on it it will work for me!
    Thanks Aaron
  11. Grego
    Grego The FLB
    counting drops of water
    Fullerton
    KS i900r for 13 months. Just a coulpe minor issues. At first could not get the seatclamp tight enough,( seatrails would slide back) but with leverage on an allen wrench got it tight. Does stick down sometimes at first activation but after bumping once it will move accordingly throughout the rest of the ride. No other problems. Great post.
  12. Waldo
    Waldo Lebowski Urban Achiever
    Foothill Ranch... but my credit card lives at The
    So out of all that, plus general considerations of look, feel, design, and price, which would you buy if you needed one today?
    Does the GD win out?
  13. kanga
    kanga Active Member
    Eagle Rock
    Gravity Dropper (3" classic with remote)... 4+ years, and still going strong. I've replaced the cable and housing about 6 times in that four years, pulled it apart to clean and lube it twice. It's simple and easy to service.
  14. Patrick
    Patrick Member
    Real Estate Expert
    SJC
    2 GD's 5+ yrs. (4-2-1 and a 0-3) Most of my riding crew has had issues with all the other suspects. The LBS's and the product mfrs warranties have all been great but still a hassle...the pain watching the fiddling, tightening, unplanned drops and nut slaps leads to one conclusion. KISS - keep it simple stupid.
    I don't recommend the Turbo. They only designed it that way so it can convert to a lever and vise versa, the cable kinks way too easily at that angle. The original is still the best.
  15. Bryguy17
    Bryguy17 A little Shaggy
    Fullerton, CA
    I've been running the reverb for around 6 months, and no complaints from me. any problems I've heard of people having can be easily solved with a bleed. it's not that bad (they give you everything you need with the post after all). it is easily the best remote on the market IMO. simple, easy to use, solid, decidedly non-janky. most of the others can't really claim all of those...
  16. reerun
    reerun New Member
    Corona
    my reverb works great for about a month then it takes lots of pressure to go down and goes up very slowly........... i bleed it..... works great for about a month ........ then the cycle repeats
  17. Fearless Fly
    Fearless Fly anachronistic and impulsi
    Mechanical Engineer
    Brea, CA
    4 years, gravity dropper, 2 broken seats. Same post.
    Gravity dropper rules!
    Buy a crank brothers and find out.
  18. wizard
    wizard tradersancho's dad
    Chemist
    Mission Viejo
    Joplin 3: one year and blew the seal
    Joplin 4: two years and performing great
    CB gave great support. No complaints
  19. JoJon
    JoJon Member
    Santa Ana
    Just over 18 months and almost 5200 miles on my Specialized command post, only issue I've had was the cable tightening up but a shot of WD40 took care of that.
  20. jae2460
    jae2460 Active Member
    +1 on this comment from above from Chewyeti:
    I've had about the same experience. It works well and is reliable, and I'm happy with it but it isn't perfect.
