29er Tire Combos/Recommendations
Discussion in 'The Workshop' started by BrewMaster, Feb 18, 2008.
  1. allison
    allison Active Member
    I just picked up a 1.9 Karma for the rear to replace my worn out Python. Will give a report Thurs night or this weekend!
  2. dubjay
    dubjay Having upgraditis is OK
    Work for publisher of fashion magazines
    Had both my Bontrager Dry X 29x2.1's blow off my Stan's Arch 29er rims this weekend. I was running them tubeless, with Stan's yellow tape, ~28-30psi with about 3oz of Stan's sealant.
    Big BANG both times, but luckily I was just climbing and going slow.
    The front tire had been mounted for 3 months - the rear was just mounted last week. I haven't had a chance to inspect for tire damage yet so I don't know the cause for the blowoffs. But I did throw in 2 tubes the tires stayed on after that.
    I'm not sure if I want to try tubeless again on a 29er for a while. I might just run tubes w/ a little sealant injected into them for a bit.
  3. Jslow
    Jslow stipend of maltliquor
    Upland
    which 29" tires are ust?
  4. BrewMaster
    BrewMaster Thirsty
    Chemist
    Foster City, CA
    At the moment, none. There is word that Hutchinson is working on a UST Python 29er. Bontrager and Geax are rumored to have some in the works too.
  5. tkblazer
    tkblazer Zack Attack
    not sure why so many peeps like those stans rims... o well not sure if any ust 29er tires will come out due to weight weeniedom but i wouldn't mind a big betty ust for a front tire... i have ust rims already on my bike :bang:
  6. allison
    KNOCK ON WOOD. I haven't had any problems with any tires on either of my Stan's wheelsets. They've been awesome. I did slice a sidewall earlier this year, but I don't think you can blame the rim for that one ;)
    I have a Dry-X on my 355's right now, and have since before VQ. I ran the Racing Ralph before, and Ignitors before that.
    I've got a 2.4 Racing Ralph on my Arch rim front, and a Captain on the rear. But, those are tubed right now.
    Though for those of you up over 180+lbs, I guess it isn't a direct comparison to take my experiences :?:
  7. kev
    kev vincit qui patitur
    Orange
    I don't think it's the rims but the tires. I've had good luck with Stan's rims using WTB and Panracer tires. I've burped my WTB Weirwolf once or twice and th Panaracer zero. No blowoffs.
  8. Code Blue
    Code Blue Guest
    Bonti's
    They are known for blowing off rims. Heck some of the older tires would blow off rims with tubes#-o
    Wirebead seem to work best for me:)
  9. jschwart73
    jschwart73 New Member
    Stouts kick ass. Gobs of grip and they don't roll nearly as bad as I expected.
    The only downside is weight, they're almost 1 lb heavier each than the tires I've been running.
    But the grip is awesome. I REALLY like the tire.
  10. BrewMaster
    BrewMaster Thirsty
    Chemist
    Foster City, CA
    Are the Racing Ralphs true to their size numbers as far as width or do they run small? Is anyone running them tubeless with Stan's sealant?
  11. allison
    I think they are probably a bit smaller. The 2.4 is more like a 2.4 mutano raptor (maybe a bit bigger?).
    I had stan's tubeless in my 2.25. It didn't last long. I've been running a 2.4, and Justin ran it also, tubed (both) and it has been fine.
  12. davidB
    davidB Active Member
    Tustin
    Small Block 8 2.1 = not a good front tire unless i'm on pavement. who knew? [​IMG]
    looking for something fatter like a 2.35-2.4
  13. BrewMaster
    BrewMaster Thirsty
    Chemist
    Foster City, CA
    When you say it didn't last long, do you mean the tread wore out quickly or the sealant F'ed up the tire?
    I am looking for a new front tire for my Air 9 because the Mountain King 2.4 (acutally a 2.25 or 2.3) is a bit too aggressive for this bike. It's a nice tire, but more suited for AM.
  14. foofighter
    foofighter Ride More Talk Less
    Aliso Pendejo
    i recently had the ability to ride on panaracer rampage fronts and maxxis ignitor in the rear and i'm really happy w/ them. the rampage are similar to the nevegal but more aggressive and seem to roll a lot faster. ignitors in the rear give a nice bite, i rarely spun out on some of the recent climbs i did
  15. BrewMaster
    BrewMaster Thirsty
    Chemist
    Foster City, CA
    Yeah, I hear good things about the Rampage. I may go that route.
  16. tkblazer
    o really what bike was this on? ;) :lol:
    rampage has been a good tire for my air9 Sammy... running spechy captain tire on the rear wheel and it has been a solid combo for everything from loose DG in the san gabes to soft dirt at sart and loose over hardpack locally.
  17. Code Blue
    Code Blue Guest
    +1 on the Ignitor
    This is my favorite all around tire. Does everything "good" not great. I guess that is why I purchased 10 of them from The Path#-o
    However I only like it in the front.:)
  18. OMR
    OMR Old Man Riding...
    Realtor
    Marietta, Georgia
    Like you, DeeZee, I prefer the Ignitor on the front... a good all around tire. The back, I'm presently running an SB8... sometimes doesn't hold on the loose climbs real well but boy, do they roll!
  19. allison
    Sidewall was thoroughly slashed. It happened at the SS Lovefest and photos have abounded on MTBR as well. It didn't even last 2 months, I don't think?
    Brian said it's unusual, and I do have another one.
    The Bonty DryX caused me a crash this weekend at Fontana, and it wanted to wash out in EVERY corner that had a little bit of built up sand. It was ridiculous. I'm gonna have to relearn how to ride a bike if the tire doesn't knock it off ;)
    Not sure what else I would be running otherwise :-k
    Justin asked if I was ready to run Karma 1.9's f/r, but I don't think I am ;) I'd need a 36T anyway #-o
  20. Pho'dUp
    Pho'dUp Spam Musubi MasherSS
    P-line rider
    The Jones Dry X is big for a 2.1 and fast rolling. But dam if those things don't want to wash out everywhere. Maybe retire them for the summer and put them back on when things are tackier.
    Plus don't pump those tires up over 40psi on a hot day tubeless = explosion.
    I use my Jones DryXs on my commuter bike.
