For Sale 2012 KHS DH300_Lucky 7; $750obo
Discussion in 'The Market Place' started by Crankset, Jan 18, 2018.
  1. Crankset
    Crankset New Member
    Riverside & Orange County
    https://www.ebay.com/itm/183020550165?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
    F.A.S.T.™ (Floating Arc Suspension Technology)
    Downhill/Free Ride Aluminum Frame w/ 8" travel and 4 bar,w/ horst; RACE FACE chain guard
    RockShox Lyrik 170mm travel
    Bearing linkage design
    ISCG05mount (E*thirteen LG1 32-36)
    Rear Shock: Fox DHX RC4; Spring: 350x3.25"
    The Fox DHX RC4 coil is a high performance rear shock at home either on All-mountain, Freeride, Downhill bike.
    Weight: 0.98 lbs / 447 g
    Length / Stroke: 222mm (8.7") / 70mm, 241mm / 76m
    Adjustments: Rebound, Low-speed compression, High-speed compression, Spring preload, Bottom out progressivness, Bottom out force adjust
    Spring: Coil
    Kashima coating on shaft
    Riding Style: All-mountain, Freeride, Downhill
    The Fox patented Boost Valve technology has a lot going in its tight little package, Boost Valve provides a feeling of endless travel and plushness like that of a downhill rig, but with XC pedaling efficiency. The smaller piggy back camber helps adjust how progressive the shock feels, with the more air put in, the harder it will be to bottom out.
    Fork: (New) RockShox Lyrik 170mmTravel (Ridden 3hrs)
    Headset: FSA FAT PIG 1.5R
    Rims: Azonic Outlaw
    Hub, Front: Azonic, Disc, Sealed Bearing, 20mm through axle 32Hx150mm
    Hub, Rear: Azonic Disc, Sealed Bearing, 12mm through Axle, 32Hx150mm
    Tires: (NEW) Schwalbe Magic Mary 26" x 2.3, Fold Bead, (Ridden 3hrs)
    Qty.2 NEW Continental Tubes
    Spokes: 14G Black, Stainless Steel, 32x32
    Derailleur, Front: N/A
    Derailleur, Rear: SRAM X5, 9 Speed
    Shifter: SRAM, X9
    Chain: SRAM
    Crankset: Gravity-GAP
    Freewheel / Cassette: (NEW) SRAM CS-HG61 X9, 11-32, 9-speed
    Pedals Not included
    Seatpost: (NEW) Specialized Command Post
    Saddle: (NEW) Specialized
    Handlebar: TruVativ, Metallic 790mm, 31.8mm
    Stem: WAVE, 45mm, 31.8
    Grips: ODI
    Brake Levers: SRAM CODE 3
    Brakes: SRAM CODE 3 (Extra Pads, qty.2 Sets)
    Color: Pearl White / Team Red / Infinite Black
    Frame Size: L
  2. Crankset
    Crankset New Member
    Sold today to sikwitiit
  3. herzalot
    herzalot Well-Known Member
    EdgeUCater
    That bike was way ahead of its time. Good price. Best wishes for a sale. Might want to try Pinkbike.
