Old 10-30-2007, 08:09 PM   #1 (permalink)
Reformed Triathlete
lukewiens's Avatar
Question rear der. cable destruction??
so i raced home from work today...threw the bike on the back of the car and battled traffic to the nearest trail-head.
geared up and headed out....wtf!!
this has happened twice now in the last few months. the section of cable between the cable adjuster and cable fixing plate is frayed destruction.
i know that is a pretty vulnerable section of cable (rocks, etc.) but i just want to be sure that something else isn't the culprit. i think the first time might have been due to over-tightening during the initial build.
it's a new xt der.
thanks.
"when you get hurt and all of your sacrifice adds up to nothing, are you willing to put it all on the line again?" - conrad stoltz
MY BLOG - EMTB Quest for 24 hours solo
lukewiens is offline
Old 10-30-2007, 08:29 PM   #2 (permalink)
Default That...
it's a new xt der.
thanks.
never happens with SRAM drl's
Check the housing it maybe frayed and cutting the cable
lukewiens (10-31-2007)
Old 10-30-2007, 09:03 PM   #3 (permalink)
Bike Industry Slave
biglimey's Avatar
it's a new xt der.
Check that the plate under the fixing bolt doesn't have any sharp edges. I've cut cables there before.....and as the der moves through it's stroke, it continues to cut it. You may just be able to file off any edges if it's the issue....
biglimey is offline
Old 10-30-2007, 09:09 PM   #4 (permalink)
Rob's Avatar
Perhaps you are over tightening the fixing bolt and cutting the cables in the process.
Rob is offline
Cable housing? RustyIron The Workshop 24 11-13-2007 08:01 PM
Cable disc brakes. sandblast The Workshop 22 09-11-2007 01:26 PM
Chris King finally makes 150mm rear hubs tkblazer General Discussion 5 09-10-2007 03:42 PM
Rear Hub?? Skeeter The Workshop 2 04-23-2007 09:05 PM
Rear hub on it's way out???? ECOdork The Workshop 6 10-03-2005 08:30 AM
