I am thinking about getting a shim to use my gravity dropper in 31.6mm seat tube. Problem is that I have a 27.0 mm post and not a 27.2 mm.
There are no shims for 27.0mm. What if I fabricated an aluminum can to bring the 27.0 to about 27.2mm? Do you think that would do?
Jay K. |
#2 (permalink) | |
Good luck! |
Did you try calling Gravity Dropper for the correct shim?
They say on their website that they offer one. C
DeeZee (10-30-2007)
Mashers Only !!
M I C (pause) K E Y (pause) MOUSE.... Mickey mouse... Mickey Mouse.... All jokes aside don't do the aluminum can thing. It WILL fail. Not in the parking lot but half way through your ride. Trust me on this one. I have seen it happen a few times. If you Truly can't locate the shim you need PM me and we can work sompin out. I can make one. HUGH ![]() |
Wrecker (10-31-2007)
You can get a 27.2 shim, but that doesn't change the fact that the post is .2mm undersized. That .2mm is enough to cause the post to slip even with the clamp tightened. It can also put unnecessary stress on the frame under the seat clamp. I don't see how a coke can shim is going to fail when it isn't in a position where there is movement. Burnish a lip on the top and it won't drop in the frame. BTW it only takes one layer for .2mm. I definitely wouldn't use a coke can for more than a 1 layer shim.
Hey Jay you should do it right. Get a custom shim made. GD told me that they would send me one for my gd to fit a 31.6 . I wont ride with a shim on my post not that it wont work I will just know its there . Kinda like I wont ride patched tubes. I will change them out . To me it is just somthing waiting to go wrong.
I went back to my thompson. I have a prototype Rase post that I am helping them develop but it is still inder construction. It will have many more positions of adjustment that the gd . Come over and check it out. What bike are you thinking about getting. I think you need to ride a Chumba that is set up correctly for you. Maybe one of our 08 EVO's Check out the mtbr reviews or even the xcl can handle everything you will be doing. |
#13 (permalink) | |
Bloated Ogre
| Post your Single Speed | PacMan | General Discussion | 224 | 09-13-2008 07:59 PM |
| Anyone using a seatpost shim? kona owners? | davidB | The Workshop | 9 | 10-07-2007 11:26 AM |
| Seat post, Headset, F Derailer, brakes, QR seat clamp | Neccros | The Market Place | 4 | 09-10-2007 02:58 PM |
| Seat Squeek | Paul000 | The Workshop | 13 | 07-07-2007 05:32 PM |
| Tutorial: How to Upload and Post RR Photos Like a Pro | LBmtb | Trail Talk | 0 | 12-04-2006 12:02 PM |
