TucknRoll
n00b of jumping
Default If running tubes, what tubes do you like the best?
I have a fairly new, fairly light weight bike and I'm still running on the stock tube in the front. The rear tire is tubeless.
For when it comes times to get a new tube, what tube do you guys prefer? I'm not looking for a heavy thorn resistant tube nor am I looking for a light weight tube that will be prone to pinches. Something in-between would be ideal.
station (12-10-2007)
roadkillross
Throw some Dee's on it
roadkillross's Avatar
the cheapest, free works too. i usually run presta valves for my dh bikes, idk why, just do
jeffj (10-29-2007), SAR_boats (10-30-2007)
stinkyrider
Prince Charmless
stinkyrider's Avatar
I've had good luck with specialized. Done pretty well with Maxxis
Horrible luck with Bontrager.
Collette
Check out Specialized Airlocks. A regular tube with their own sealant inside. Not cheap at $12.00/each, but you'll be using the same tube for a WHILE.
MyTurnerBike
SSinGA
Free-XC-Downhiller
SSinGA's Avatar
Continental tubes worked best for me.
www.t2bikes.com
2wheel_lee
Old-school BMXer
Agreed on all points.
Especially with the bad luck on the Bontragers: the valve stems always rip out of the tube. I'm sure someone's thinking that I'm not doing something right, but I've been using presta tubes for more than 25 years, and Bontrager and Continental tubes are the only ones I've had problems with the valve stems (the Continentals I had problems with were likely from the same batch, which I purchased at the same time - haven't used them since).
Specialized (which I believe are made by Kenda, as are most company's tubes) are great.
Sharky
Trrrippin'
Sharky's Avatar
I swear by Specialized T-R racing tubes (presta). They are thorn resistant but lightweight. A bit tricky to find sometimes but get mine at San Dimas Incycle. Saw them at the Path but out of the presta at the time. Both stores appear to stay pretty well stocked on the goods though!!
Division 26
SAR_boats
Vanilla Gorilla
I agree with Ross. Cheap is good. Free is better.
If you want to run sealant you can use a hypodermic needle to inject Stans into a regular tube (either by removing the valve stem or injecting straight into the tube and then putting a self adhesive patch over the injection point.)
Pain Freak (12-09-2007)
ShinKen
STR BUB!!
ShinKen's Avatar
Thumbs up
u can do this or some SLIME tubes!! cheaper (like 4 to 6 bucks) and prob the same weight!! that's all I use on my 29er and they work!! it takes me a long while to replace them and if u really want to go cheap u can paTch em till their life just runs out!!
autoduel
autoduel's Avatar
I had 2 specialized turbo ultralight tubes purchased at the same time had a leak around the valve stem out of the box.
Steve
Just along for the ride
ghixon
Which way did he go?
ghixon's Avatar
Specialized tubes have worked fine for me so far. I run Slime in them from the get go and haven't had any major issues with thorns, sticks or from running over small children.
Used Bontragers a few times and for some reason, they both seperated at the valve.
ShinKen (10-30-2007)
ShinKen
STR BUB!!
ShinKen's Avatar
Cool
SLIME tubes have not done that to me!!
EVER.
northshore
northshore's Avatar
I just run the Performance Bike generic Forte thick skin brand. I paid something like $3 for the tube. I don't remember the specs but I haven't had any issues with them.
Hawaiian Island Creations
Ride it: dw-link.com/reasons
http://kencolada.blogspot.com
ghixon
ghixon's Avatar
EVER.
Where do you find the Slime tubes? I can only find them in a 26/1.75 or a 26/1.95 around here. I'm looking for some 26/2.1 for the XC setup.
ShinKen
STR BUB!!
ShinKen's Avatar
Talking
I'm pretty sure some of the LBS can order them for ya!! hmmm do they make em that size? never really noticed!! if they was 26 or 29ers size that's all I cared for.
ghixon (10-30-2007)
ghixon
ghixon's Avatar
I'll have to bug the LBS. Thanks
.8down
parts hoarder
.8down's Avatar
believe it or not Ive been running the Performance Forte tube and its been pretty leak and puncture free. knock on wood.
Originally Posted by .8down View Post
Hi my name is Thai and I'm a Partsaholic
OldDogDan
OldDogDan's Avatar
Default Not the cheap(est) tubes!
I usually buy tubes on sale, but always open the box to check them. I like the short plated stems, and it doesn't always specify on the box. Here's why I posted this: On a recent ride I gave away my spare (example on the left), so naturally, even tho I hadn't flatted in a coupla months, I then got a flat. So someone gave me the one on the right. This one snapped right in half, and I was being careful! I never had this happen before! I never liked the long brass stems, for looks, vulnerability to snagging, and possible leverage on stem base while pumping. And on some cheap ones, the stem machining looks rough. But I never expected this. Caveat emptor. So I continue to open the box and check 'em. I say get 'em short & plated.
BrewMaster
Treading Trodden Trails
I'm with Jose. I swear by Slime Tubes.
Jenson has 'em for $6. Price Point has them for $5 and Jenson will price match this.
Above all accomplishments, character matters most.
ShinKen (12-10-2007)
Rockinthecasbah
Maxxis welter weight not quite super heavy but pretty thorn , pinch resestant unless your chewy yeti
I Think I Got White Lighting In My Eye **chewyeti**
Utopia Optics
OT - Trail Running JamR General Discussion 10 10-21-2007 06:34 PM
Running and Riding: How much is to much? Evil Chocula Racing and Training 22 10-12-2007 11:44 AM
Speaking of running... X-terra Cristal Cove Pilas Racing and Training 3 10-08-2007 08:27 PM
Running as part of training? 0gravity Racing and Training 19 04-05-2007 09:12 AM
