Old 10-29-2007, 04:05 PM   #1 (permalink)
Professional Lion Tamer
Keith B's Avatar
Default Fritzed head tube ??
I was jsut doing some upgrading to my SS and noticed that there are 2 cracks in the head tube!
Both cracks are about 1/3" long (Forgive me your majesty for using old school units) one from the bottom and one from the top. God knows how long they've been there because the thing is usually filthy!
Is this the end of the line for the frame or is it possible to do a weld inlay and repair if you can someone thats skilled in Aluminium (compensating with the spelling for my earlier non metric faux pas)
I'd be gutted to scrap this frame is its chainstay length means I dont need to run a chain tensioner plus its made from uber light Columbus Zonal tubing. Its only normally used for fireroad and smooth trails but I'm not keen on the fork making a bid for freedom through the headtube incase I take another spill and pick up a further stresss fracture in some of my own metal. Any ideas??
"I once met three guys named pain, suffering and sacrifice. Now, we're inseperable. We're best friends"
Keith B is online now
Old 10-29-2007, 04:09 PM   #2 (permalink)
.8down's Avatar
sell me the parts? hahaha
.8down designs
.8down is online now
Old 10-29-2007, 04:12 PM   #3 (permalink)
Just put a couple hose clamps on there. It should be fine
I'll let the welders chime in as I'm just being a smart-ass today.
Sorry to hear about your bike.
Old 10-29-2007, 04:21 PM   #4 (permalink)
Code Blue's Avatar
Default Some questions
What is the make and model?
How old is the frame?
Was this the factory installed HS?
As it seems that this thread may be headed for the usuall as of late STR Down hill spiral JSims
Code Blue is online now
Old 10-29-2007, 04:34 PM   #5 (permalink)
Keith B's Avatar
Its a British made Hinde M3. It may well be that when the HS was pressed in the damage occurred and i never noticed. I also thought of using hose clamps Craig LOL!Frame is year 2000
Some nice stuff on it - XTR cranks, Hope mini MONO's.
Old 10-29-2007, 04:37 PM   #6 (permalink)
watch out for that pole!
Burner's Avatar
sounds like it's time for you to build up a SS 29er Keith
The Path... it's worth the drive from LA.
Burner is offline
allison (10-29-2007), ShinKen (10-30-2007)
Old 10-29-2007, 04:42 PM   #7 (permalink)
A little dab will do me
spookydave's Avatar
is it an alum or cromo frame?
Big bikes are good for your soul.
spookydave is offline
Old 10-29-2007, 04:42 PM   #8 (permalink)
time to retire that bish.... no reason to try and ride around on a cracked frame
tkblazer is online now
Old 10-29-2007, 04:51 PM   #9 (permalink)
Keith B's Avatar
DOHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!! This is two totalled frames in like 4 months!!!
What do you do with old frame sets that are making a bid for the great bike shop in the sky?
Old 10-29-2007, 04:58 PM   #10 (permalink)
.8down's Avatar
Trophies in the Garage.
.8down designs
Old 10-29-2007, 05:03 PM   #11 (permalink)
Mashers Only !!
HUGH's Avatar
Can you post a picture of the cracks? Also if you could find on the frame what kind of aliminum it is that would be a big help.
HUGH
HUGH is offline
RacinJason (10-29-2007)
Old 10-29-2007, 05:09 PM   #12 (permalink)
Keith B's Avatar
Here's the spec from Columbus: http://www.columbustubi.com/eng/4_3_6.htm
also see this page about the 700 series alloy - lookslike TIG only http://www.columbustubi.com/eng/3_2.htm
will post pics later
Old 10-29-2007, 05:11 PM   #13 (permalink)
i'd save it for the races... would make a great noise maker
Old 10-29-2007, 05:25 PM   #14 (permalink)
good times
LBmtb's Avatar
There's your problem!
My Twits
tkblazer: wonder if i can wear my yellow speedo
me: only if you wear the matching yellow goggles with it
LBmtb is offline
andy aka rut (10-31-2007), Pain Freak (10-29-2007), SAR_boats (10-29-2007), ShinKen (10-30-2007)
Old 10-29-2007, 05:26 PM   #15 (permalink)
Keith B's Avatar
LBmtb (10-29-2007), Pain Freak (10-29-2007)
Old 10-29-2007, 05:27 PM   #16 (permalink)
Buy like a cheapie frame from Jenson or similar. Unless The Path has cheap steel HT frames? Sounds like you have all the good parts for a new frame.
allison is offline
Old 10-29-2007, 06:03 PM   #17 (permalink)
Code Blue's Avatar
Default Do you know why
the British automakers decided not to make computers? It was imposible to get them to leak oil
foofighter (10-29-2007), Pain Freak (10-29-2007)
Old 10-29-2007, 07:31 PM   #18 (permalink)
Columbus Zonal is self tempering 7000 series aluminum, so having to re-heat treat the frame is a non-issue.
You have 2 options:
You can weld in a piece of 1" 7000 Aluminum in the headtube and swap headsets to 1" ( I can hear the groans already)
or
You can have a machine shop cross drill and face the cracks to stop their path, then ream out the headtube 1/10th of an inch then sleeve it with 50/1000 inch 7005 tubing then weld it in place and then fill in the cracks and holes with welding rod
Or get a new frame
mtnbikerfred (10-29-2007), Schecky (10-30-2007)
Old 10-29-2007, 08:09 PM   #19 (permalink)
Keith B's Avatar
Here we go..........
Old 10-29-2007, 08:13 PM   #20 (permalink)
After seeing the pics, I say just duct tape it.
allison is offline
