As it seems that this thread may be headed for the usuall as of late STR Down hill spiral JSims |
.8down (10-29-2007),
genusmtbkr5 (10-29-2007)
If you're going to run 3 rings up front and say 11-34 cassette in the rear, then you will need a long cage. Some guys only that have freeride or some all-mountain bikes only run 2 rings up front, you can use a med cage then. The long cage allows for the chain to wrap around that "big" ring. The long cage also takes up the slack if you when your'e in your small rings, because the chain is much longer when running 27 speeds
The general guidelines stated so far will get you there.
If you want to get really geeked out, you can find out the chainwrap capacity of any rear der. If I remember corectly, the formula to calculate chain wrap is the difference between the tooth count on the biggest cog on the cass and the smallest added to the difference between the smallest chainring and the bigest. So if you have an 11-32 cass, and 22,32,44 rings (32-11)+(44-22)=43 |
destroyer (10-29-2007),
Dino Brown (10-29-2007),
foofighter (10-29-2007),
genusmtbkr5 (10-29-2007),
mtnbikerfred (10-29-2007)
![]() Call the shop and tell Brian to find me a ACS 22t freewheel ![]() ![]()
thephat (10-29-2007)
Also, road bike derailleurs are available in short and long lengths, but the road long is the same as mtb medium (my memory is getting a little fuzzy on this). Related, I've tried running Ultegra derailleurs on my M3 (with an Ultegra cassette), but the plate the B-tension screw threads into bends and breaks (it's aluminum vs many mtb derailleurs that are steel). The vibrations and constant chain bouncing in DH use just kills it. And yes, my chain is long enough.
#10 (permalink) | |
My Blog |
What do you mean that it looks like it's for road?
#13 (permalink) | |
If you want tight and compact, look no further than the 2008 Shimano XT "Shadow" rear derailleur. You're not going to get any tighter or more compact in the Shimano lineup. It comes in medium and long cage versions (maybe short, but I haven't seen it yet). After abandoning the Ultegra RDs, I've had great results with this new XT RD.
