Old 10-27-2007, 09:43 PM   #1 (permalink)
TwoLeggedHorse's Avatar
Default Ghost Shifting from Hell
Getting straight to the point, my bike is ghost shifting. The shifters/derailleurs are Shimano XT. Either on a straight away or bumpy incline, the chain on my bike tends to shift on its own from one high gear to one low . I've tried dialing the rear shifter, but it hasn't worked. Then I attempted to tweak the high and low settings on the rear derailleur, but that hasn't work. I'm at a point in my life I just want the buy a whole new derailleur.
Any advice to solve my problems would be great. Thanks guys.
Twoleggedhorse
07' Kona Dawg Primo
TwoLeggedHorse is offline
Old 10-27-2007, 10:02 PM   #2 (permalink)
Warriors Society Member
KeepsWhatHappens's Avatar
Did you recently replace any part of your drive chain such as your chain?
Sometimes if you replace one part of your drivetrain and you've waited a while to make that change the act of putting a new part (such as a chain) into the "old system" can cause skipping or ghose shifting.
Or is your deraillerur bent?
KeepsWhatHappens
KeepsWhatHappens is offline
TwoLeggedHorse (10-28-2007)
Old 10-27-2007, 10:04 PM   #3 (permalink)
bjammin's Avatar
Install a new rear drr. cable and make sure the length of housing that runs from the chainstay to the drr. is not too short. If it is, it will cause the drr. to move ever so slightly as the suspension cycles resulting in shifting havoc.
If this doesn't work...throw a rock at it.
bjammin is offline
jeffj (10-27-2007), Shannon (10-28-2007), TwoLeggedHorse (10-28-2007), Wrecker (10-28-2007)
Old 10-27-2007, 10:08 PM   #4 (permalink)
genusmtbkr5's Avatar
KeepsWhatHappens
I think he just bought the bike at the last Path parking lot sale which wasn't that long ago.
Gene"GuidesNewWarriors"
http://www.sharemtb.com/
genusmtbkr5 is offline
Old 10-27-2007, 10:13 PM   #5 (permalink)
Sloths Mock Me
jeffj's Avatar
Assuming the cables slide easily in the housings and shifters work freely...
- Cable adjuster on rear derailleur backed out all the way from derailleur
- Cable housings too short/tight, especially those at the RD or near the BB
- Bent hanger
- Bent RD
- Loose cassette "nut"
- Download the derailleur installation instructions from Shimano's website and follow the adjustment instructions. It's pretty straightforward to set the stop points and how to line up the RD pulley to the cassette.
That's where I would start.
jeffj is offline
Old 10-27-2007, 10:27 PM   #6 (permalink)
On the edge of chaos
Abui's Avatar
Twoleggedhorse
High and low settings on the derailleur only act as stops.
(When you say it always ghost shifts from high gear to low gear you must mean from a smaller cog to a larger cog, right?)
You need to adjust the cable tension. Put the bike in a stand or have someone hold the rear wheel off the ground. Turn the cranks and shift through all the gears. Shift into 2nd. Turn the barrel adjuster on the derailleur until the chain starts to skip up to 3rd gear. Back off a little. End of quick fix.
edit - 2nd here means second smallest cog, etc.
Abui is offline
Old 10-27-2007, 10:32 PM   #7 (permalink)
I agree with caveman. The bike is only a couple of months old. Unless you crashed and bent something, it's probably just cable tension.
Old 10-27-2007, 10:41 PM   #8 (permalink)
one wheel drive
pollu_sean's Avatar
2 things, make sure the cassette is secure, a loose cassette will cause havoc on shifting. second, make sure cables are lubed and they slide easily in the housing. i had recently found that whoever cut the housing for my cables pinched one end causing the cable to bind there...fixed easily by pulling the nipple off the offending end and widening the hole a bit. problem solved.
Heckler
pollu_sean is offline
Old 10-28-2007, 06:28 AM   #9 (permalink)
This can be one of those nerve wracking problems that drive you nuts!
I had similar issues with one of my bikes. I have always been able to dial my derailuers in without to much problem, but this last time took a lot of work. I finally gave up and went back to my LBS. The owner who I trust more then anyone to work on my bike took a long look at it and suggested we change the middle ring. We did and problem was solved, but I fought this thing for two months before this finally solved the problem. I'd say take it to the LBS and let a competant wrench take a look at it.
Old 10-28-2007, 11:15 AM   #10 (permalink)
coldbrews's Avatar
I was having the same problem with my new bike 2 mos. ago when I bought it. I took it in 3 different times one right after the other, each time they fixed it they told me it was the cable stretching. Finally after the third visit I havent had any more problems.
I would give Cavemans suggestion a shot.
coldbrews is offline
Old 10-28-2007, 12:04 PM   #11 (permalink)
Default Has it been back in
Have we had a shot at this one yet? It sounds like it may be covered under our free post sale sevices.
thephat is offline
Old 10-28-2007, 01:34 PM   #12 (permalink)
Shu
Team Brittle
Shu's Avatar
Myself and 4 others all bought Hecklers at the same time and from the same shop....1 of the bikes has had this problem from the 1st ride....it has been in to 3 different shops inc the shop that the bikes were purchasd from 2x's(no warrenty attempt to fix)...NOBODY has been able to fix the problem yet ALL claim the problem is solved..it happens on flats...climbs...but can also be intermitnant....won't do it for the 1st part of the ride but constantly on the 2nd half AND vice versa..ALL the tips listed above have been tried by myself...bike owner...LBS...Look out Path it's on it's way to you this week....
07 Bionicon Golden Willow
Rat Rod cruiser
Shu is offline
Pain Freak (10-28-2007), steviebfromtheoc (10-28-2007), thephat (10-28-2007)
Old 10-28-2007, 01:47 PM   #13 (permalink)
mytrustysteed's Avatar
This is my method for fixing EVERYTHING!
Riding a Specialized Stumpjumer :-)
mytrustysteed is offline
bjammin (10-29-2007), Pain Freak (10-28-2007), Wrecker (10-28-2007)
Old 10-28-2007, 02:18 PM   #14 (permalink)
Abui's Avatar
Bike with problem - low normal derailleur?
Abui is offline
Old 10-28-2007, 02:57 PM   #15 (permalink)
Default Single pivot
Make sure everything is tight on the frame. A flexy frame can cause shifting fits.
[SIZE=1]ps:[/SIZE]
[SIZE=1]Warning smart a$$ comment coming[/SIZE]
[SIZE=4]GO SINGLE SPEED!!!!!!!!![/SIZE]
J_Sims (10-28-2007), TwoLeggedHorse (10-28-2007), Wrecker (10-28-2007)
Old 10-28-2007, 03:25 PM   #16 (permalink)
Shu
Team Brittle
Shu's Avatar
We have gone over EVERY bolt/nut/screw/cog/chainring...anything that can be tightened has been....
ThePhat the bike is a black Heckler owned/riding by ClDrnkr(Rob)....I'm telling him to talk to you or Sarah b/c you to or the only names I know from the shop...
Rat Rod cruiser
Shu is offline
Old 10-28-2007, 03:35 PM   #17 (permalink)
THE Penultimate Mtb'er
Wrecker's Avatar
Hmmm, Halloween, Ghost shifting...coincidence? Someone had to say it
Take it to the Path, always more productive to have them work on a bike than to throw a rock at it. If it is a new bike, could be cable stretch, in which case, follow Caveman's advice. But then, what the hell do I know?
"There are too many factors you have to take into account that you have no control over...The most important factor you can keep in your own hands is yourself. I always placed the greatest emphasis on that."
Wrecker is offline
RacinJason (11-01-2007), TwoLeggedHorse (10-28-2007)
Old 10-28-2007, 06:13 PM   #18 (permalink)
Dirt is good
DirtRider's Avatar
Take it to your LBS... i read somewhere on STR of a few good ones... i had a very similar issue and took it to my LBS. they took it back behind the black curtain and a few minutes later it was shifting and holding gears perfectly. i did see some smoke and heard a few curse words from behind the curtain. They told me that was standard protacol in fixing ghost shifting.
DirtRider is offline
jeffj (10-28-2007), TwoLeggedHorse (10-28-2007)
Old 10-31-2007, 11:57 PM   #19 (permalink)
The problem is that it is a Shimano. Convert to SRAM and say bye to ghost shifting. Worked for me and never looked back. I was always fumbling around with my XT's. After the initial adjustment on the X series, you literally never have to touch it again.
92se-r is offline
