#21 (permalink) |
defending Lady Singletrac
here's how you get out a small, low-torque,stripped allen bolt-
you use a screw extractor, but you don't drill a hole down the center of the bolt! (that's a great way to get broken pieces of bolt stuck in there). Use an extractor BIGGER then the diameter of the bolt shaft, just the right size so the tip will fit into the cap of the bolt where the hex key usually fits. Now, the rounded tip of the extractor will still be a little smaller then the hole in the cap, so you use a rotary sanding pad in your drill and grind down the end of the extractor, flat, until it fits in the stripped hole nice and snug. put it in your screwgun, put it in stripped hole, and back it out; the sharp edges of the screw extractor will grap the sides of the hole. you have to use the spiral(kinda looks like a drill bit0type of extractor, not the square-cross-section type. This may not work if the bolt is really seized in there, though. Oh, and get a new bolt!! |
#23 (permalink) |
No, it is the pad retention bolt on the caliper of a new set of Avid Code 5's. It stripped like butter on my first attempt at loosening it. I wanted to check out the pads after I went riding due to some noise issues. The brakes work great but right now, I'm debating whether to fix it my self or return them and play dumb.
#24 (permalink) |
One thing i forgot to mention. Snap-on to has an easy out set that has a drill guide: because if you go off center while drilling a bolt its all over ( well you can use a re-thread kit if required). It takes some practice! Heat is also an option, you can also use a punch on the center of the bolt to loosen it. Last resort ( I have used it before on a stubborn jaguar head bolt) you can have it removed by laser. Their is a company in Santa Ana that can do this. I don't recall the name but an internet search will send you in the right direction.Sorry, this type of thread is my gig, i love to fix stuff!!!!
Rossage (10-25-2007)
#25 (permalink) | |
Steve Peat Wannabe
| Grasshoppers... can we get a head count, please. | OMR | General Discussion | 31 | 10-25-2007 12:48 PM |
| Brian Head for Labor Day 9/1-3 | denmother | Trailhead | 41 | 09-04-2007 01:45 PM |
| RR: Brian Head Day 1 | mtnbikej | Trailhead | 8 | 08-26-2007 01:47 PM |
| Just got back from Brian Head | jfromlv | Racing and Training | 5 | 08-08-2006 09:04 PM |
| Stripped Lock ons | imapodaddy | The Workshop | 4 | 06-23-2005 04:13 PM |
