Steve Peat Wannabe
O.K., so I'm not new at this; I've bled Hayes brakes a dozen times or so. However, I'm having a problem this time. I had a kink in the line, so I cut the line (clean cut), put on new fittings, re-attach the line to the master cylinder, get it all nice and tight, give it fluid, tap the frame and lines to get air out, do the draw back, tighten everything up, blah, blah, blah.
So here's the thing: After I tighten everything down and seal the system, I give it a couple pumps, and it's not really engaging (it does ever so slightly, but not really). So I flip the master cylinder (brake lever) back up, take out the screw, and it looks like there's not enough fluid in there. So, I pump more fluid in from the caliper until, again, fluid starts coming out the top. I seal everything off again, give the lever a few pumps...it's not really engaging...I flip the lever back up...the whoe cycles goes like this again, again, again. I don't get it? ![]() Anyways, I thought it was the master cylinder itself, so I grabbed a complete rear brake that I knew worked (at least it did last time I used it), cut down the line (cuz I need it for the front), and the same thing is happenning. So this would be VERY coincidental if there was a mechanical problem with these two brakes, but somehow, I don't think that's the problem. I can take an allen wrench to the adjuster screw and get it to where it finally engages, but the lever is waaay out there, and if I look in the master cylinder, it still looks like there's not enough fluid?!?!? ![]() So my question is, can anybody read this and tell me what the problem is? Maybe I'm just pulling some bonehead move and forgetting to do "X", and although it's just a little thing, it's the reason for my problem. Any help is GREATLY appreciated. Oh, the brakes were Comps and Mags...same problem. Cheers ![]() |
#3 (permalink) | |
Steve Peat Wannabe
Should I not give it quick taps, but more even, slow, gentle pushes? |
Suck on these
yes that is the trick pull slowly and let go slowly and give one more squeeze of the bottle make sure no air in fluid coming out of master and and tighten the bleed valve and then put screw back in master
Why ask why, does it really matter???????? |
project_d (10-22-2007)
Maybe I can help.
It's kind of hard to follow what is happening from your description. Lets see: From what I read is that when you pull the lever it basically goes down all the way to the handlebar, unless you adjust the screw. Are you using a bleed kit of some type or are you just doing the lever pull thing only? |
Steve Peat Wannabe
This whole process repeats itself over and over. It's almost like air is coming into the line somehow, or I'm not getting all the air out, but I don't see how. I've looked all over the line and fittings, and it does not appear that fluid is leaking from any place. ![]() |
Here's what you can do. I'm glad you have a bleed kit. for a minute there I thought you were just doing some type of gravity bleed. Anyways. The reason you're getting the air in the system feel is because of your brake lines. When you compress your lever your lines basically expand. Giving it the extra pull. This is why braided line are are popular because when you pull the lever it doesn't expand; therefore, stops exacty at a certain point instead of getting the little extra pull. Now to fix your problem.
if that is the case the best thing to do is repeat the steps and get a feel for how much extra to add. Give this a shot. i do this trick with all my brakes hayes or not, and my friends brakes. so i'm hoping it will work for you also. |
| Hayes El Camino brakes | Shu | The Workshop | 17 | 10-19-2007 11:05 PM |
| Hayes Sole Hydro brakes and rotors | Chewyeti | The Market Place | 1 | 10-17-2007 08:38 AM |
| Hayes HFX-9 Carbon Disc Brakes Set F&R $100 | mntbiker12 | The Market Place | 4 | 09-06-2007 06:51 PM |
| Avid Rotors with Hayes Brakes? | Evil Chocula | The Workshop | 17 | 08-17-2007 01:29 PM |
| Hayes HFX-9 HD Dixc / 205 mm rotor F+R's are really bad brakes. What can I do?! | UseItOrLooseIt | The Workshop | 20 | 08-25-2006 10:47 PM |
