So I've only had my BB7s since June when the bike was new, but already the rear rotor is warped to the point where it is hard to set up the rear brakes so they don't rub the pad.
Is it possible to re-flatten a rotor without doing even more damage? If so, how should I do this? Thanks.
天ery few are meant for a life of notoriety, yet all of us are meant for a life of significance." Erwin McManus, Wide Awake |
If it's not that bad, just take an adjustable wrench and slowly bend it back into position a little at a time.
BrewMaster (10-22-2007)
Bananaseat: i'm hitting it on a regular basis |
Thanks Nam. I think I will buy a new rotor and then play around with the warped one to see if I can make it live again.
OMR (10-24-2007)
I had a rotor that had a bend in it. It wasn't too bad, but it wobbled enough to heavily rub both sides. I noticed it the night before I did a fast and steep DH ride. After the ride, the rotor was straight! I'm guessing that using it [a lot] under those conditions - I nearly cooked the brakes - may have straightened it out. That was a couple years ago, and I am still using that rotor.
Sam...
i have some nice barely used 6" and 8" hayes rotors..... tale your pic for the trade of a tasty brew
Chewy THE Yeti Call me Chewy or Aaron VOODOO Gonzo 29 Big Boys ride.....BIG wheels. |
Throw some Dee's on it
there is a tool made by park tools, that perfectly hooks to the rotor and you bend it
Offroadie-"I ride a fixed gear, but I'm no hipster." dirttorpedo- "i like the runs..........: |
Forgive my ignorance, but would Hayes rotors work with Avids? Do they all have the same bolt pattern for attaching to the hub? If it works, I'll take you up on the offer.
yeah any rotor should work with any caliper. ive had trouble with hope rotorson my hayes just because the machined center was a tad bit wide. other than that your golden. ppl will jsut think your running hayes.
the only different hub patterns are shimano rotors with the centerlock. other than that, they'll 6-bolt.
yep... 6 on 40mm iirc....
ive had both hayes and avid rotors on my ride... all the same. bring some tasty bier and swap em at my casa. got torx sockets and loctite ready for ya.
l'homme plus
Pony up a few bucks to buy a new one from the "take off" bin at your local shop.
Downhill Web Kook Git sum! |
all better?
BrewMaster (10-24-2007)
On the edge of chaos
Adjust your BB7's so that the rotor is as close to the inside brake pad as possible. Unlike a hydraulic brake only the outside pad of the BB7 moves so every braking usage tends to warp the rotor. edit - if you use a non-Avid rotor check (how?) that the arms are as beefy as the Avid. |
I haven't ridden it yet, but things look to be in great shape. I am hopeing to ride today. Thanks for the rotors Aaron!
| Hayes 7" rotor and adapter | guero | The Market Place | 8 | 10-01-2007 07:41 AM |
| Rotor Replacement Recommendations | Nic | The Workshop | 9 | 08-22-2007 03:06 PM |
| Disc Brake Rotor Design Question | Chewyeti | The Workshop | 6 | 08-13-2007 01:45 PM |
| wanted: 203mm rotor. | FOCKER | The Market Place | 3 | 09-08-2006 05:19 AM |
| Hayes HFX-9 HD Dixc / 205 mm rotor F+R's are really bad brakes. What can I do?! | UseItOrLooseIt | The Workshop | 20 | 08-25-2006 09:47 PM |
