Old 10-17-2007, 02:54 PM   #1 (permalink)
Rossage's Avatar
Default brake problems
I have a stuck piston on my Juicy 5's, anyone know how to fix it?
Rossage is online now
Old 10-17-2007, 03:03 PM   #2 (permalink)
Client 9
Fired Yo Momma's Avatar
buy a new one I love your Avatar!!!! In High School I was a total Specolli.
And the hangovers hurt more than they used to And corn bread and ice tea took the place of pills and 80 proof
And it seems like none of us do the things quite like we used to do
And nobody wants to get high on the town
And all my rowdy friends have settled down
-Hank Williams Jr.
Fired Yo Momma is offline
Rossage (10-17-2007)
Old 10-17-2007, 03:07 PM   #3 (permalink)
TURNERob's Avatar
Take the pads out, caliper off and soak it with WD-40.
TURNERob is offline
Old 10-17-2007, 03:11 PM   #4 (permalink)
Default And things
have changed how..........
Back to the topic. If it is not leaking then you may just need to pull the piston(s) out and clean them. Replace the fluid and bleed
Old 10-17-2007, 03:14 PM   #5 (permalink)
Rossage's Avatar
In high school I even had the stoner van that we all fell out of in a haze of pot smoke!
I'm gonna try TurnerRob's fix first. Then I'll try the real way....
Old 10-17-2007, 03:17 PM   #6 (permalink)
Client 9
I had the 78 honda accord CVCC puke marroon with the house speaker in the trunk as my "system" with the bongs under the seat.
-Hank Williams Jr.
Old 10-17-2007, 03:23 PM   #7 (permalink)
I just had this problem with an old Hayes caliper. I removed the pads, and I dabbed a Q-tip dipped into brake fluid around the caliper piston. I then squeezed the lever, forcing the piston out only a little bit, then I dabbed the Q-tip around it again. Then I pushed the pistons in. Basically, I cycled the pistons a bit while dabbing the outside of them with the brake fluid. When I was done, I sprayed the caliper with contact cleaner, and reassembled everything.
DeeZee (10-17-2007), Rossage (10-17-2007)
Old 10-17-2007, 03:27 PM   #8 (permalink)
Rossage's Avatar
I took out the back seat of a '69 volkwagen van, nailed a bed together, and then broke it on the very first try at getting it on!
Sprayed WD-40 on it and it works like new! Thanks TurnerRob!
Old 10-17-2007, 03:28 PM   #9 (permalink)
Default I agree with this also
if this does not fix the issue then see my previous post.
Old 10-17-2007, 03:31 PM   #10 (permalink)
That was going to be my next step. But I've been doing a test with these brakes to see how little maintenance I can give them. I first got them in around 1999 or 2000, and this is the first time I've had the slightest problem with them. If the piston sticks again, they're coming out for a thorough cleaning.
Old 10-17-2007, 04:35 PM   #11 (permalink)
Rossage's Avatar
My can of WD-40 is MIA so I used the q-tip and brake fluid method and after a few mins my piston came free. Thanks for the help.
Later, Rossage
2wheel_lee (10-17-2007)
Hayes Brake Rotors & Pads project_d The Workshop 10 10-17-2007 08:40 PM
Check your brake cables UR2KLOS General Discussion 15 09-06-2007 11:28 PM
Brake lever pin missing Paul000 The Workshop 4 08-07-2007 11:09 AM
Brake levers scorns General Discussion 6 10-31-2006 09:43 PM
Avid Mechanical problems Flat Broke The Workshop 11 10-18-2006 11:10 AM
